Author Topic: th350 to 700r4 shift indicator swap  (Read 6129 times)
Offline BigBadJohn
« on: August 18, 2009, 07:39:16 pm »
Im starting to put the cluster back in but the clip on the column is different from the clip for the 700r4 indicator.
Do I need the old style clip and wire and attach it to the pointer for the 700r4 indicator or what?
I was hoping to get the bezel back on and put the radio in and drive it some but ran into this problem
If so, the joker I bought the truck from clipped the cable off at the clip and took the th350 indicator out.
Offline DnStClr
Re: th350 to 700r4 shift indicator swap
« Reply #1 on: August 19, 2009, 01:12:53 am »
Is this what you have?  The bigger clip? You can swap them out. It shouldn't cause any problems.
Don
87 Chevy Silverado
Offline BigBadJohn
« Reply #2 on: August 19, 2009, 01:39:37 am »
Yeah. I need the big clip on mine
I guess I can get one on ebay or something
Offline DnStClr
« Reply #3 on: August 19, 2009, 11:57:01 am »
I saw two of em on there just last night. The clips were both small tho.. I used to have an extra around here somewhere. I'll go look for it and let you know.
Aha.I have a big clip and a small one.(with wire) No indicator for an overdrive tho. Just two indicators for 3 speed.
Send me a pm with your mailing address and I'll send it to you.
« Last Edit: August 19, 2009, 12:15:15 pm by DnStClr »
Don
87 Chevy Silverado
