Author Topic: 1987 305 tbi stalls  (Read 4316 times)
Offline 87wrangler
1987 305 tbi stalls
« on: August 19, 2009, 05:34:02 pm »
Hi, i bought my 87 wrangler a little over a month ago and sometimes when i start then start to drive without letting it warm up it will stall, this has only happened to me a few times and i am not to familiar with tbi everything else i own is carburated. andy help is appreciated. also i did run some fuel injector cleaner in it a while ago.
Re: 1987 305 tbi stalls
« Reply #1 on: August 19, 2009, 05:46:38 pm »
What codes are you getting?
Offline 87wrangler
« Reply #2 on: August 19, 2009, 06:25:57 pm »
what do you mean by codes? dash lights?
« Reply #3 on: August 19, 2009, 09:06:39 pm »
The computer should be throughing up codes if it has running issues. The check engine light should be on, or coming on, and off?
« Reply #4 on: August 19, 2009, 11:14:18 pm »
Start with the basics and tune it up. Liquid medic won't fix it. You can retreive diagnostic trouble codes with a paper clip jumping the a&b terminals in the data link connector under the dash. It will flash the check engine light in a morse code. example flash pause flash flash of the check engine light is code 12. Report
Offline 87wrangler
« Reply #5 on: August 21, 2009, 04:27:33 pm »
thanks for the help guys.
« Reply #6 on: August 24, 2009, 06:09:40 pm »
What did you find?
