Author Topic: how to remove crank for panel  (Read 7481 times)
Offline 84chevyboy
« on: August 20, 2009, 08:54:20 pm »
well today i just aquired to nice donor doors i will be takin tha glass and channel out of tha pass. side for my power windows, but i need to find out how to take of tha crank so i can take off tha panel to get inside tha door. thanks.
Offline low budget
Re: how to remove crank for panel
« Reply #1 on: August 20, 2009, 09:28:53 pm »
Go to an auto parts store and get one of these:
 http://www.lockpickshop.com/LT460.html
Here is step by step instructions of how to get the clips off.  It's easy...
http://www.ehow.com/how_2112895_install-car-window-crank-handles.html
Hope this helps...
Offline gold84gmc
« Reply #2 on: August 21, 2009, 07:47:32 am »
having one of those tools makes it a lot easier to do
92 buick century custom 3.3L
Offline Flamingbig10
« Reply #3 on: August 21, 2009, 03:00:47 pm »
Ive used a small slotted screw driver before
« Reply #4 on: August 21, 2009, 04:02:06 pm »
I use a red rag. If you look at the back of the handle, you can see the open end of the clip. Take a rag, and loop it around the handle beteen the panel where the open side of the clip is facing the bottom of the loop you made in the rag. Now just pull the rag working the ends back and forth a little and the clip pops out.
Offline low budget
« Reply #5 on: August 21, 2009, 05:50:05 pm »
Wow, Chop, I'll have to try that.  I always used a small screwdriver also...
Offline DnStClr
« Reply #6 on: August 25, 2009, 09:43:56 am »
Great tip, Chop! Thanks.
Don
87 Chevy Silverado
