Author Topic: fixed leak but still leakin  (Read 4306 times)
Offline 84chevyboy
« on: August 20, 2009, 08:59:13 pm »
ok i got all tha seals and stuff fix on tha tranny pan but then i found out that that speedo cable was leakin so i changed it out now to days later is not leakin but can see fluid on the cable rite were it goes into tha tranny what could be tha prob. thans its a stock 84 tranny also
Re: fixed leak but still leakin
« Reply #1 on: August 20, 2009, 09:29:27 pm »
Spell check chevyboy. It's hard to follow... Where is the fluid coming from?
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #2 on: August 20, 2009, 09:52:58 pm »
Quote
That's like, 'it's raining outside but it's not raining'  ???
Offline 84chevyboy
« Reply #3 on: August 20, 2009, 09:55:33 pm »
lol. ok my tranny was leaking bad so i changed all the gaskets and seals. now a few days later i notice the speedometer cablle a fluid on it right were it screws into tha tranny,so i decide to change it,after about two days i went to check it out i notice a little fluid on the new cable it. it wasnt alot but it was noticable.
« Reply #4 on: August 21, 2009, 05:09:10 am »
So you replaced the seal in the speedo gear?
Offline 84chevyboy
« Reply #5 on: August 21, 2009, 06:16:11 am »
yea i did
« Reply #6 on: August 21, 2009, 06:53:15 am »
Take it back out and check it.
Offline sleepchamber
  • working on it...slowly...
« Reply #7 on: January 16, 2012, 09:15:12 am »
Vile, what is the size of the print that needs to be replaced?  I'm having the same leak on my truck.  Thanks.
1985 Scottsdale C-10
