Author Topic: Doors  (Read 5903 times)
Offline greenmonster
Doors
« on: August 21, 2009, 05:56:31 am »
Can I put 75 door internals in a 77 and up door and just get new door panels.
Re: Doors
« Reply #1 on: August 21, 2009, 11:41:28 am »
Not unless you want to to use 73-76 door panels, which won't cover the holes in the lower section of the door.
Offline bigblock73
  • Yeller
Re: Doors
« Reply #2 on: August 21, 2009, 08:42:36 pm »
No you cannot.  Not only do the door panel differ, but the 73-76 door guts are different than the 77+.  The window crank shaft is shorter, and the roller channels that are spot welded to the inside of the door are different in size.  Ask me how I know all this.  :(
Jeff
'73 swb 2wd
73-87.com
Re: Doors
« Reply #3 on: August 22, 2009, 01:11:01 pm »
Thanks for the reply.I just bought 2 77-87 door shells for $150.Is there any thing I can use for my 75 door in the 77-87 like the glass,vent window,latches,handles,locks ect.
Offline 80stepsideguy
Re: Doors
« Reply #4 on: August 22, 2009, 02:07:15 pm »
You can use everything in the 77-91 doors from the 75 doors.The window regulator arm for your windows will be shorter (?)  then the 77-91 style. Other than that and the door panels everything else should be a direct bolt in..
thanks
pat
p.s. MY 1000TH POST on this forum  ;D ;D
1998 Chevy 1500 S/B 2wd
Re: Doors
« Reply #5 on: August 22, 2009, 11:24:33 pm »
YEAHHHHHH FOR PAT PARTY
« Last Edit: August 22, 2009, 11:27:26 pm by Irish_Alley »
