Author Topic: excessive play on the axle shaft  (Read 3396 times)
Offline rudnik
« on: August 22, 2009, 06:55:53 pm »
i went to replace the locking hubs on my 78 k20 and when i pulled the passenger side  hub off i noticed that the axle shaft has play in it.  i can move the shaft maybe a quarter inch in and out and side to side and up and down.. the driver side has no play in it at all.. i took the tire off and i can do the same thing if i play with it at both ends of the ujoint...
so does anyone have any idea what this could be?
Re: excessive play on the axle shaft
« Reply #1 on: August 22, 2009, 07:55:15 pm »
Sounds like the u-joint is bad
« Reply #2 on: August 22, 2009, 11:32:48 pm »
like vile said u joints or maybe bearings?
Offline rudnik
« Reply #3 on: August 24, 2009, 08:44:11 pm »
i think i'm going to end up just replacing everything.. i dont think the ujoint is bad, cause there is play before it in the shaft too.. but figure better safe than sorry
