Author Topic: Is there a replacement for the Rear cab mount floor rib section???  (Read 7652 times)
Offline Yeti_North
I have 2 1980 c10 One a parts truck one a builder. Is there a replacement for the Rear cab mount floor rib section??? I have been searching but I cant find any info on it. I got 2 trucks for free one cab is done but the back is good the other truck cab is good but the rear cab mount brace is rusted out do they make a replacement for it? I only need one side driver side. as I said I do have a cab with a good one but I would rather replace with new if possible.
YeTI
« Last Edit: August 24, 2009, 06:25:42 am by Yeti_North »
Re: Is there a replacement for the Rear cab mount floor rib section???
« Reply #1 on: August 24, 2009, 06:03:07 pm »
I am not sure what area you are talking about
Offline joesgarage71
  • Wrench
« Reply #2 on: August 24, 2009, 06:53:52 pm »
 Post a pic of it!
Offline Yeti_North
« Reply #3 on: August 24, 2009, 09:13:28 pm »
I will get a pic in the morning.
YeTI
Offline Marc
« Reply #5 on: August 26, 2009, 06:44:48 am »
If you make a template a sheet metal shop should be able to make one or two to slip on over it if all else fails.  Suprised it is so bad with the oil coating underneath and the rest of it looks good.
« Reply #6 on: August 26, 2009, 05:24:39 pm »
that piece is not produced, you are going to have to make something to fix it.
Offline Yeti_North
« Reply #7 on: August 26, 2009, 08:28:42 pm »
Crap. Ok I will cut the one out of the other cab i have.
Tnx for the info.
YeTI
« Reply #8 on: August 27, 2009, 08:06:08 pm »
Street sign post works good.
