Author Topic: The Distributor  (Read 6071 times)
Offline eramirez198121
The Distributor
« on: August 26, 2009, 09:29:47 pm »
Hi it me again lol. I will make this one short and to the point. I have a point distributor that I put on a 1974 Chevy 350, the thing is that it as a singal wire that connected to the distributor where does it go? ??? As you can see I am not that go with wiring.
Offline ccz145a
Re: The Distributor
« Reply #1 on: August 27, 2009, 12:28:56 am »
What does it connect inside?
My guess would be the - side of the coil.
Offline maddog
Re: The Distributor
« Reply #2 on: August 28, 2009, 06:37:42 am »
That is correct on the Neg (-) side of coil
Re: The Distributor
« Reply #3 on: August 28, 2009, 03:42:04 pm »
Thanks!!! :)
Re: The Distributor
« Reply #4 on: August 29, 2009, 08:55:47 am »
Just get rid of that points distributor and convert it to HEI.
Offline joesgarage71
  • Wrench
Re: The Distributor
« Reply #5 on: August 29, 2009, 07:45:54 pm »
 Yup that the way to go but remember that the wire from the ignition is a restor wire and you need to change that so you have a good 12V to the dist.
 Steve
