Author Topic: Turbo 350 ? for Vile or anyone else that really knows these trannies  (Read 2985 times)
Offline Russ130
I'm planning on replacing the hard line for the modulator just because the current one is messy and unsightly. While at the parts store the guy told me to go with as small a line as i could in order to increase the pressure and slow down the modulator a little. I have noticed my truck shifts early but figured thats just how it is. I have installed the govenor shift point kit and it is at the latest possible shift currently. I also have the adjustable modulator and really see no difference one way or the other. Is this caused by having too big of a vacumn line running to the modulator? Is the size of the line actually a way of fine tuning the shift points of a 350? Any other thoughts about vacumn line sizing and applications like brakes, pvc or heater controls?
Re: Turbo 350 ? for Vile or anyone else that really knows these trannies
« Reply #1 on: August 27, 2009, 08:00:49 pm »
This guy doesn't know his :( from his elbow obviously. Make sure you have vacuum at the modulator. A smaller or bigger hose will not make any difference. Get a pocket screwdriver and adjust the set screw to delay your upshifts if you want a later shoot.
