Author Topic: WIRING TO STARTER  (Read 4477 times)
Offline kfoz
  • ALWAYS BUILD WITH BRICK & STONE ! ! !
WIRING TO STARTER
« on: August 28, 2009, 09:08:13 pm »
Does anyone have a pic or know exactly where the STEEL elbow tube that holds the starter wiring mounts to? There are two areas on the tube where it monuts(one 3/8" hole tab and one 1/4" hole tab)
Thanks much!
kfoz
kfoz (kfoz@comcast.net)
'73 C20 4 Speed 2WD
Re: WIRING TO STARTER
« Reply #1 on: August 29, 2009, 08:27:19 am »
To the bellhousing bolts or studs.
Offline kfoz
« Reply #2 on: August 29, 2009, 09:58:12 am »
Thats what I thought.  It looks like one goes to the tranny tube mounting tab?-- but is close to the head pipe.
So, where does the smaller mounting tab(on the elbow) mount to? I don't see a stud anywhere.
kfoz
'73 C20 4 Speed 2WD
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #3 on: August 30, 2009, 12:47:15 pm »
Here's a pic of the lower attachment.  As Vile points out, a bell housing bolt keeps the main attachment in place.  When I removed my old 350 out of my 79 way back when, I took hundreds of pics...here's one...excuse the oil drips--one reason I replaced the old 350....
Offline kfoz
« Reply #4 on: August 30, 2009, 06:50:22 pm »
Thank you so much. It appears that the lower tab mounts to the stock starter! No wonder, I have a mini-starter! DUH!
I just couldn't remember where the thing mounted!
Thanks again.
kfoz(Kelly)
'73 C20 4 Speed 2WD
