Author Topic: Battery and other HOTs have contiuity to ground  (Read 16483 times)
Offline EvilleIron
  • 76 C30
« on: August 31, 2009, 06:32:08 pm »
Hi,
Im new here, and I have a big problem.
My truck is stuck at work.
About a week ago my starter key got stuck on and has been messed up since.
So far, the alternator has been replaced, the control module was too.
Also the key cylinder.
Auto zone tested the starter, ign coil and module, coil was ok. He said the starter was using alot of amps, but works.
After doing all this, I checked the contiuity to the pos battery cable, the alternator + and plug, and the coil +.
and it buzzed.- not good.
I did not put the battery in after checking and replacing this stuff.
I'm no mechanic, but Ive worked on this truck for years.
Any Ideas of what else to check. Thanks.
It's a 76 C30 2wd SRW Custom Delux, with no ac or cruise or nothing.
Very simple truck- usually.
Brian
Re: Battery and other HOTs have contiuity to ground
« Reply #1 on: August 31, 2009, 07:07:25 pm »
You cannot ohm a live circuit. I'm not sure what you were even trying to accomplish by doing that.
Why don't you start over and tell us what your truck is doing. Will it not crank the starter motor?
Offline EvilleIron
  • 76 C30
Re: Battery and other HOTs have continuity to ground
« Reply #2 on: August 31, 2009, 07:41:20 pm »
Hello VileZambonie
Sorry if I wasnt clear.
My truck shorted somewhere, I think.
I used a Fluke voltmeter with continuity buzzer.
The battery is not in the truck. The pos terminal/wire is resting on the plastic wash tank.
I got continuity between the positive battery cable and chassis.
I got continuity between the pos alternator and both prongs in the plug to chassis.
I got continuity between the hot wire from the coil to the chassis.
I'm terrible at electrical, but I dont think this is right, so I havent put the battery in.
It's as though the positive battery cable was grounded, unless Im missing something and did something wrong, but I dont think so.
When it first happened, and I replaced the alternator,  When I went to put the battery in, it arced like when jumper cables are crossed. It fried the new alternator. I now have a 2nd replacement alt.
Today I pulled the coil and module, and the module was also fried.
I put it all back in and tested the continuity again before deciding not to put the charged battery back in.
It still has continuity in all those places to chassis. Is it supposed to?
Thanks for the reply.
Brian
« Last Edit: August 31, 2009, 08:17:19 pm by EvilleIron »
« Reply #3 on: August 31, 2009, 08:26:40 pm »
If it's connected you WILL have continuity. Now check your fusible links and if they are ok put the battery back in.
Offline EvilleIron
  • 76 C30
« Reply #4 on: August 31, 2009, 08:33:49 pm »
ok, thanks.
The parts are installed, except the battery.
I'm just not understanding why open positive wires would buzz with the chassis on the tester.
Maybe a rubbed wire.
Brian
« Reply #5 on: August 31, 2009, 08:53:48 pm »
It doesn't mean it's open. Just because the source voltage isn't present you have not opened the circuit. A mechanical switch for example opens a circuit. If you check the B+ side of the fuse and to it's ground you will have continuity. The circuit is powered off so your continuity test is useless unless you are tracing an isolated circuit. Check those fusible links first. Do you know where they are?
Offline EvilleIron
  • 76 C30
« Reply #6 on: August 31, 2009, 09:06:30 pm »
I cant recall from memory where they are, but I know what they should look like.- I'm working on a couple of my trucks presently.
Thanks for the help. I'll get back to it tomorrow.
Just paranoid to fry something(s) again.
Brian
« Reply #7 on: September 01, 2009, 09:57:26 am »
Look down by the starter motor where the B+ cable connects and look at the junction block on the firewall.
Offline EvilleIron
  • 76 C30
« Reply #8 on: September 02, 2009, 04:04:43 am »
Thanks, everything looked fine and I put the battery in.
There was no arcing this time, but the voltmeter is reading higher at higher rpms.
Offline BigBadJohn
« Reply #9 on: September 02, 2009, 11:37:00 pm »
Ruin his voltmeter maybe?
Although a small voltage like this and DC nonetheless probably wouldnt destroy it. Still not a good idea
« Reply #10 on: September 03, 2009, 07:07:17 am »
Fluke meters are top notch, and have built in safety measures to protect the meter from damage. When checking for shorts, I use the ohm setting to check the resistance that way. Sometimes the beeper will go off on acceptable readings. The best way for me is to set the meter between the pos and neg, and start disconnecting components until I see a substantial change. Its also best to check amperage draw on the systemwith the key off, but not everyone has access to that type of meter. You'll know real quick if there is a drain because the battery wont last long
« Reply #11 on: September 03, 2009, 09:03:42 am »
Ohming or checking continuity of a circuit is nearly pointless unless you isolate the circuit. Checking continuity through wires will easily mislead a novice because you will have continuity through devices that should have continuity. People instantly assume this means a short to ground which is not necessarily the case.
Checking amperage draw using your meter (non inductive) you need to break the circuit and install the meter in series or your meter will become the load in the circuit. Your hand held meter won't take 600A  :o so be careful. If you are checking ESD sensitive components best stay away unless you know what you are doing with that meter.
Offline Marc
« Reply #12 on: September 03, 2009, 07:03:12 pm »
What was the original problem?  Did the key stick in the start position and crank?  Or did you let the key go and did it crank?
What does the voltmeter read that has you worried?
Offline EvilleIron
  • 76 C30
« Reply #13 on: September 09, 2009, 07:58:45 pm »
Thanks all,
I dont know whats going on with it.
Marc, yes the starter got stuck on in the on position.
That may be attributed to a worn key cylinder that would take almost any old square gm key.
so far, the key cyl, alternator (X2), control module and now the starter have been changed.
The starter is a spare, but I tried to run it with the previous one
and thats when I suspected the old starter. Thats when I think I fried something again.
 'shoulda changed it before I put the battery in, if it is fried.
Anyway it runs- poorly- I drove it 10 miles home with 1000lbs of veg oil in the bed.
The hi voltmeter reading I mentioned is the truck's ammeter in the dash.
It overcharging. It used to always be right on 13.
After the weekend it was re-assembled, the battery was stone dead.
I charged it all day and got it home - somehow. 10 miles. and it restarted right away when I shut it off in the yard.
I never put any meter to it while the battery was in it.
I was trying to the best of my limited electrical ability to find a short in the wiring.
And the reason I'm writing this today is because I dont have experience with diagnosing electrical problems.
I live pretty close to an AdvanceAuto, and will limp over there to get free testing. I also got both alternators there.
Brian
« Reply #14 on: September 09, 2009, 08:31:38 pm »
Lets refresh a little and start over. What are the symptoms now? You said it was overcharging, what is it charging at right now? Lets see what its doing now, and start over so we can see if we can help.
