Author Topic: 454 in a 83 diesel...too many wires  (Read 4884 times)
Offline dragon08
  • New Users
« on: September 06, 2009, 06:43:26 am »
73 454, very simple motor & now many extra wires under the hood & through the firewall.  is there an easy way to identify those i might need? can i just cut the ones i don't need? or is it better to chase them through to the fusebox & pull them?
Offline dragon08
  • New Users
Re: 454 in a 83 diesel...too many wires
« Reply #1 on: September 06, 2009, 08:04:36 am »
i'm also having problems with the water temp sending unit.  do i use the one for the diesel or the new gas motor? the gage reads 220, but it doesn't seem that hot.
« Reply #2 on: September 06, 2009, 08:07:23 am »
Are you sure you have the correct wire? Pull it off the sender and check the gauge. If you're sure you don't need the other wires, cut them and label them, then tuck it back in the harness loom neatly. Write on a piece of paper what each wire went to and throw it in the glove box.
Offline joesgarage71
  • Wrench
« Reply #3 on: September 06, 2009, 08:40:40 am »
wiring diagrams are in the tech section
