Interior & Equipment
turn signal issue?
Topic: turn signal issue? (Read 8375 times)
slowchevy
turn signal issue?
September 08, 2009, 08:00:08 pm »
ok i had turn signals then i didnt have any all i did before losing them was unhook a trailer brake set up and i then noticed no turn signals i dont know if i lost them before or after doing that but all other lights work brake lights and all but heres where i got confused my hazards work on the dash and the front but not the rear of the truck i switched out the silver fuse for one out of a 73 and still didnt work my truck is a 78 4x4 any help would be nice thanks
Re: turn signal issue?
September 08, 2009, 08:34:26 pm »
check the ground on the bed.
slowchevy
September 08, 2009, 09:13:01 pm »
where should that be at???
slowchevy
September 09, 2009, 12:00:06 am »
ok well i dont think its the ground i noticed the hazards do work in the front and back just not the blinkers
September 09, 2009, 12:44:39 am »
do they not work at all or are they solid? did you mess with the trailer plug at the bumper. could it be a fuse i think they are separate from hazards
slowchevy
September 09, 2009, 01:58:41 am »
theres nothing they dont show anything even on the dash i got flashers in all 4 corners i checked the big round silver fuses i swaped them in and out and all i had was hazards only thing ive messed with was the ground on the gas tank to get the gauge to work and i messsed with the trailer brake box i have under the steering wheel one of the wires touched but i dont know when the blinkers stoped working just noticed i havent checked the little glasss fuses yet could it be one of those if you got any ideas would be nice i cant think of what it could be thanks for any help
September 09, 2009, 06:32:30 am »
the silver things are flashers not fuses. it should be a glass fuse tho
slowchevy
September 09, 2009, 02:37:21 pm »
is there any diagrams of the fuse box person that owned the truck before me painted everything even the fuse box even the fuses
September 09, 2009, 02:49:31 pm »
All the wiring diagrams are listed in the tech forum. Just look at 77-80_instrument_pg2.jpg
slowchevy
September 10, 2009, 12:51:15 pm »
my fuse box is nothing like the one in the diagram
September 10, 2009, 02:42:34 pm »
What is yours like, there were only 3 versions.
slowchevy
September 10, 2009, 08:59:53 pm »
mine has a flasher fuse on the top left then one on the bottom right
Reply #12 on:
September 11, 2009, 08:33:58 am »
Don't know where you were looking but that is what the one here has:
http://www.73-87chevytrucks.com/techinfo/wiring_diagrams/77-80_instrument_pg2.jpg
turn signal issue?
