Author Topic: Having a problem with my gear ratio i think  (Read 20579 times)
Offline rick_c
« on: September 19, 2009, 11:02:28 pm »
Hello again, been gone for a while...
Have an 82 swb, just built a 350 9.7:1 flats .030 over 4 bolt main 010 block.
A lunati 489/504 lift voodoo cam 268/276 duration, 1.5 roller rockers, untouched 76cc heads with 1.94/1.50 valves with 550 max lift springs, edel rpm intake a 1406 carb. Built a TH350 with a tci pump red eagle clutches koleen steels and a b&m stage 2 kit. Also a jegs 2200-2400 stall (that doesnt stall right). Oh and a melling high vol. pump (big mistake)...don't ever use one of those...I run 80psi at 1000 rpm! all my seals are starting to leak.
just so everyone knows where I'm at.
Ok so the problem I'm having is figuring out what gears I need to run.
I've always thought this truck had a 3.08 geared 10bolt.
i serviced the diff today and counted the teeth.
Apparently it is a 2.73? which I didn't even know existed.
With what I'm running, the truck runs okayish on the street, I can pretty much take anything in my neck of the woods except a couple of sleepers( a stroked 05 GTO, and a wrx with a huge turbo).
I can smoke the tire(no posi) on a 20 roll manually shifting it at about 6000rpm.(very fun!)
I can make the dotted lines blurry in 2nd gear going into third running about 6300rpm. Don't know how fast that is because the speedo stops at 85.
My question is, what gear would yall recommend to keep my highway running conditions but be able to tear up the street on take off?
Right now if I stomp on it from a stop it will spin the tire but it lags real bad.
I'm thinking a 3.90ish gear...if thats even possible with the low numbered carrier.
I hear the old heavy halfs had a factory 12 bolt 4.10 posi...
All advise is appreciated...Thanks
Re: Having a problem with my gear ratio i think
« Reply #1 on: September 19, 2009, 11:11:49 pm »
I personally would get a 3.42... Still decent rpm's when highway driving but should be a great improvement off the line.
Offline rick_c
« Reply #2 on: September 19, 2009, 11:31:48 pm »
Forgot about that gear...just wonder how much harder it would pull off the line.
I also have destroyed a new set of brute force u joints from shifting too hard I guess..
Is there a more heavy duty brand than that? Thats all we sell at auto zone
« Reply #3 on: September 20, 2009, 02:32:02 am »
you got dura gold lol. well building that engine at the zone, i hope you didn't buy from them causes there probably investigating you right now the hole "shrink" thing .when you say it lags at take off what do you mean. if your spinning at 20 with a wot then i wouldn't go and lower than what you have, you will just being putting more money into the tires but i mean your running above 6k spinning and all i would eather invest in a posi about the same ratio or traction bars or better tires or all three. whats your 1/4 time? spinning ain't winning.
« Reply #4 on: September 20, 2009, 05:09:18 am »
How about a 3.73 with a 700R4? A high volume oil pump won't make all your seals leak.
« Reply #5 on: September 20, 2009, 07:54:31 am »
+1, make sure your PVC system is working properly.
Offline joesgarage71
  • Wrench
« Reply #6 on: September 20, 2009, 08:45:48 am »
Look for a 12 bolt rear, buy a posi, with the TH350 you have I'd go for 342 gears, 373 gears will be about 3000RPM at 70mph. forget about getting that GTO, and the WRX you might get him off the line but he'll be eating your lunch at half track.
Offline eventhorizon66
« Reply #7 on: September 20, 2009, 11:08:45 am »
It'll just rob you of power and suck your stock pan dry at 6000 rpm.
'85 C10 SWB 350 700R4 TKO600
« Reply #8 on: September 20, 2009, 07:48:40 pm »
If you have .0035" bearing clearance or more then a high volume oil pump is fine. If you have a high capicity oiling system then fine. Otherwise a standard volume pump is proven fine. A prelube system is a better investment.
Offline rick_c
« Reply #9 on: September 20, 2009, 10:35:22 pm »
Yea the duragold...bought all my stuff there kept the reciepts though.
The lag thing is I dont pull as hard off the line as I do if I'm rolling and stomp on it.
I guess that has to do with not being in the cam at take off.
I'm thinking about spooling the rear but I hear it annoying to drive with one.
Don't know the 1/4 time but I doubt its anything to write home about...the nearest track is over 100 miles away.
I wouldnt spin on the track like that I don't think. I'm doing that on asphalt roads that arent prepped.
Is there a u joint on the market that I won't destroy or am I stuck with changing them every 1000 miles?
Offline rick_c
« Reply #10 on: September 20, 2009, 10:44:39 pm »
The oil pump problem is weird...I thought it would be a good idea at the time, but I'm not happy. Maybe the motor will loosen up over time but right now at idle in gear I'm running 65psi when its warmed up when drive it under normal conditions it runs about 75 to 80 psi cruising around. my gauge stops at 80 and its pegged at full throttle.
I'm getting oil seeping into the valleys the center bolts on the intake go through.
The front seal is seeping and the motor only has about 1500 miles or so on it.
I think I need to check the vacuum too, but I don't know what it should anyways so that wont help me any. Unless someone here knows, and can tell me.
The GTO and WRX can suck it, I'm not wasting my gas on them.
« Reply #11 on: September 21, 2009, 10:31:33 am »
The center two bolts on either side of the manifold need thread sealant or they will leak, regardless of your oil pressure.  Apply this stuff to the threads.
The front seal should have RTV applied to the outside of the metal shell before installing it.  And that would also NOT be affected by oil pressure.
If your oil pressure were 150 psi, neither of these locations should leak.
« Last Edit: September 21, 2009, 10:45:29 am by eventhorizon66 »
Offline SUX2BU99
« Reply #12 on: September 21, 2009, 10:43:41 am »
I had a 2.76 open 12 bolt when my motor work (see sig) was done last May. I certainly didn't have the traction or u-joint problems you do but I've always felt my carb is screwed up and I just haven't done anything about it. My trans shifts HARD though on the 1-2, enough to (I think) cause the crush sleeve in my diff to keep moving around, wiping out 3 ring and pinions now. Anyway, it sounds like your have some power to play with and that's great. Not sure why you are having such u-joint problems though. Are you having any vibrations that come through the floor or seat? Does your trans shift pretty hard? Do you do neutral drops? Is your pinion to driveshaft angle appear to not be inline even closely?
I went from a 2.76 to a 3.40 to a 3.73 ratio. My 3.73s with 295/50-15 tires spins at about 3000 at 60 mph. Kinda high but that's about my tolerance limit. A 3.42 you might like.
As for traction on street vs strip, for some reason I seem to have more traction problems at the track.
Offline rick_c
« Reply #13 on: September 21, 2009, 02:08:27 pm »
Thanks for the info. Funny thing is we sell that stuff at my work, but I never thought to use it.
I used an aftermarket timing cover so I think the seal might be cheap.
Going to pull it off and change it to a felpro. I have to put a timing tab on it anyways
Offline rick_c
« Reply #14 on: September 21, 2009, 02:23:23 pm »
No vibrations that I've noticed unless I'm stopping because I cooked on of the rotors when a caliper stuck and havent replaced it yet.
The trans shifts hard enough that Ive replaced the rear pass side tire three times since April because I keep popping the belts. Was using BFG T/A radials but switched to Firestone indy 500 tires and havent broke one yet. 275/60r15 is the size Ive been using.
I never do neutral drops, and always make sure that I completely stop before going from reverse to drive... The pinion angle might be an issue under torque load because I had someone tell me that it looked like the pinion yoke goes down some when I take off. Don't know what would cause that though. I'll try to take a pic of it a try to figure out how to post it on here so yall can tell me what yall think.
BTW, you have a sort of similar setup to mine, so what is your timeslip?
Like to know ballpark where I'm at since I can't take it to the track...
