Author Topic: weather striping... in windows  (Read 7252 times)
Offline malibu795
« on: September 21, 2009, 08:50:08 pm »
picked up a kit to do both sides including then vents.
got the inside and outsinde horizonatal channels and then window track all the way around.
got hte dirveside window done... didnt do the vents since is rquires oen to drill out old rivets and install the new weatherstripinng with new rivets...
now the window is VERY stiff while going up and down... i believe i bent the window arms that hold then window itself  >:(
anyone got any idea on how to make is smoother? before i do then passside window..
and the rivets for the side vents would be helpful as well.
adam wildman
75 K25 383/400
Offline jim84
Re: weather striping... in windows
« Reply #1 on: September 23, 2009, 03:29:22 pm »
just wondering where you picked up the kit? I need to do the same.
Offline malibu795
« Reply #2 on: September 24, 2009, 09:50:11 am »
bout it out of JCwhitney.
i havve but petroleum jelly in then channel area and it seem to be working smoother and easier.. still bent then window lift system on then dr side...
adam wildman
75 K25 383/400
« Reply #3 on: September 24, 2009, 11:57:19 am »
You replaced the run channel around the glass and it got hard to roll up/down.
did anything get bent?  Is everything adjusted correctly?  What all did you change? (other than the weatherstripping)
Offline malibu795
« Reply #4 on: September 24, 2009, 08:15:24 pm »
i replace then flet strip all the way around then main glass.. nold taken out.. new was put in... nothing else was change... and for some reason then window jumped out of then grove... :( and its raining...
adam wildman
75 K25 383/400
Offline 1980c10
« Reply #5 on: September 25, 2009, 01:29:09 am »
I would check the track that go inside the door on the back side of the window. i am guessing that when you removed the window you may have pushed it a little too far back as this track is easy to bend which explains both problems. with your door panel off and your window up you should be able to reach inside and pull it foward. be carfull though as sometimes the track becomes seperated from bracket that holds it to the door. which reminds me check that too in case that happened.
Offline malibu795
« Reply #6 on: September 25, 2009, 10:22:35 am »
that was bent backwards int hen first place... i pulled back forwards... maybe not enough
adam wildman
75 K25 383/400
« Reply #7 on: September 28, 2009, 03:30:17 pm »
If it is jumping out of track and then you moved it you need to "adjust" it again.
Offline malibu795
« Reply #8 on: October 12, 2009, 07:26:28 pm »
i think i ordered weather striping fro 80-87 turck instead of 73-79 turck.... :-\
adam wildman
75 K25 383/400
Offline swcu_21
« Reply #9 on: October 18, 2009, 11:02:05 pm »
I ordered a weather stripping set online and was wondering what the best way to change the track stipping is? I havn't really had a chance to look at it, they are electric, but i would like to avoid a window sticking from applyig too much torque.
Workin on reviving my great grandpas 86 GMC 1/2 ton. 350/290 crate in; Tranny in planning stage.
