Author Topic: tranny trouble  (Read 3430 times)
Offline bmaier
tranny trouble
« on: September 23, 2009, 07:42:42 pm »
Here's the deal: I got a '79 C10 awhile back and at the time it ran somewhat rough and the tranny shifted fine. Lately the engine started running rougher and rougher. My brother took the pickup to his autos class at the tech and they looked it over and found the problem to be mismatched plug wires and the Accel ignition setup. they replaced the cap, rotor, plug wires...etc with stock parts and junked the accel setup. runs great now, but now the tranny isn't shiftin/shiftin right. it shifts sometimes and i also got it to shift if i ran through the gears manually. any ideas? its a C10, 305/350 combo.
Re: tranny trouble
« Reply #1 on: September 23, 2009, 08:20:43 pm »
They probably knocked the vacuum hose off to the modulator.
Offline bmaier
Re: tranny trouble
« Reply #2 on: September 24, 2009, 07:08:56 pm »
i will check that out tonight. thanks vile.
Offline joesgarage71
  • Wrench
Re: tranny trouble
« Reply #3 on: September 24, 2009, 07:46:54 pm »
That or caused it to leak, its located behind the carb and in front of the distubtor. Steel line with a short piece of hose conecting the line to a fitting at the top of the intake.
« Last Edit: September 24, 2009, 07:50:37 pm by joesgarage71 »
