Author Topic: 700r4 crossmember  (Read 6760 times)
Offline Hotrod Steve
700r4 crossmember
« on: September 28, 2009, 09:51:37 pm »
Hello
I'm in the process of putting together a 700r4 for my 83C-10.
Replacing a 4 speed manual SM465 granny low.
Will the manual crossmember work with the 700r4?
Do I have to get the correct auto crossmember?
Offline aussie
Re: 700r4 crossmember
« Reply #1 on: September 29, 2009, 07:23:08 am »
 i think there the same trans mount i had a turbo 350 trans it was the same crossmember i noticed some crossmembers are not straight like mine they have a reccessed area seams like its for a cat
Offline 87OldYeller
« Reply #2 on: September 29, 2009, 10:00:53 am »
OK the 700r4 is the overdrive tyranny right? is that electric o/d or manual. Cause my though was a 700r4 once a time ago. But was told it would not shift in to o/d with out the wiring.
« Reply #3 on: September 29, 2009, 03:24:39 pm »
The only electronic function of the 700R4 is the converter lockup.  otherwise it is a 4 speed with 4 being overdrive.  Without the electronic connection the converter won't lockup.
The crossmember should work, its position and the trans mount will likely be different.
Offline aussie
« Reply #4 on: September 30, 2009, 06:30:33 pm »
bowtie overdrive sell a lockup convrter kit about $100 last time i brought one esay to install
« Reply #5 on: October 01, 2009, 02:58:26 pm »
