Author Topic: Air comming out A/C vents when on Heat and Defrost  (Read 5271 times)
Offline Kelsfine69
« on: September 30, 2009, 04:23:26 pm »
I have a 1987 Silverado with A/C. When its on heat I get some air "bleeding" out the A/C vents. Same when I go to Defrost and then when I go to A/C or vent I get more airflow from the dash vents. Is there something I can check without tearing the whole hearter box out? Everything seems to work ok but I dont like warm air blowing in my face when i have the heater on. Thanks
Re: Air comming out A/C vents when on Heat and Defrost
« Reply #1 on: September 30, 2009, 07:34:15 pm »
Make sure the vacuum hose is hooked up in the engine compartment coming out of the firewall to a vacuum source.
Offline Kelsfine69
« Reply #2 on: October 01, 2009, 09:02:54 am »
yea like I said everything works but some air comes out the vents when on heat. I wonder if the heater control could be leaking?
