Diagnosing a no-start condition
Topic: Diagnosing a no-start condition (Read 13770 times)
werewolfx13
Site Supporters
October 04, 2009, 08:03:42 pm »
The problem I thought I fixed by replacing my cap, rotor, coil, ignition module, and ignition switch has come back..Today I replaced the ESC dist. with an Accel hei distributor, reused my accel super coil, still same problem. Gets fuel, gets power to the distributor both on key on and cranking, but no spark. My next plan of attack is to replace the coil (for the second time this year) with another high performance coil of some kind. Can anyone think of any other problems before I go drop another $80 on another coil? I ruled out my tach first off by disconnecting it. Everyone thus far has agreed with me, I've eliminated all other options.
Chris
'83 Chevy c10 Silverado SWB
choptop
Extended cab fanatic
Re: Diagnosing a no-start condition
October 04, 2009, 08:25:19 pm »
Make sure the button in the center of the distributer cap is making good contact with the rotor, and the spring at the end is making good contact with the coil. Most autoparts places can test the coil before you buy a new one, so try that as well.
TexasRed
October 04, 2009, 08:36:49 pm »
You could also just buy the replacement coil they sell at the store, prolly like $20. . . is this a daily driver?
October 04, 2009, 08:39:57 pm »
You replaced this distributor with an accel distributor from where? Is this a new dist?
werewolfx13
Site Supporters
October 05, 2009, 12:12:48 am »
new dist from auto zone, truck is a daily driver, but its driven hard...Since my dad has bought two 300 I6 Fords and still has no hitch on his only GM truck, I've been dragging a homebuilt 3 axle trailer packing 14,000+ lbs of logs when one of them goes down usually 2-3 times a month, and even with no load, I wail on my truck. It sees a fair amount of 4k+ rpm driving. I replaced the distributor for two reasons: 1, I wanted the upgrade, 2, I wanted to rule out the distributor itself rather than just bypass the ESC. The new dist is an accel p/n 59107c.
I'll have the coil checked out before I replace it, I'll also check the spring and button connection.
Chris
October 05, 2009, 01:47:00 am »
so you fixed it and it ran but then the problem came back? not sure if i told you this before but i was having problems with my dis. it was getting power up to the dis but no spark. then i realized i bent the male connection in the dis the female was plugging in but no contact between the two
werewolfx13
Site Supporters
October 05, 2009, 02:58:49 am »
I've checked that over, as I had the coil on and off a couple times,the connections are still straight. I'll make another note of it when I check the button and spring. I'll also check that the ground is making good contact.
Chris
October 05, 2009, 04:44:33 am »
Quote from: Irish_Alley on October 05, 2009, 01:47:00 am
are you reusing anything else?
October 05, 2009, 09:34:20 am »
I don't know what the original prolbem was but If it was ignition Eliminated the ESC would be my first step.
Are you using the same distributor connector. Did you get a new distributor with and ESC hookup or did you modify the wiring to eliminate it?
werewolfx13
Site Supporters
October 05, 2009, 12:48:31 pm »
new dist is an accel that eliminated the esc entirely, ONLY thing i reused was the coil, which i had checked today and its good, checked the new ign module several times and its good, tried swapping the button and made sure the spring makes good contact, all OK..all the cranking recently, as well as being the same starter as was in the truck when I bought it has brought the starter to the end of its life, it cranks twice strong then rolls over slow, even with 3 different batteries that are all known to be good and fully charged, as well as trying to jump it at the same time. So, tomorrow after work it looks like I'm going to see if the spare starter I have will fit..If that doesn't fix it, the manager at AZ said they'd exchange the distributors with me when they get another in on thursday, with the pickup coils being suspect.
Chris
October 06, 2009, 12:11:28 am »
granted its under warranty but a pick up coil in the long run would just be cheaper if they gave that to you and i think they can be tested with a ohms tester. when you said no spark you mean you pulled a wire and had a test light on it?
werewolfx13
Site Supporters
October 06, 2009, 08:04:13 am »
I pulled a wire and used an extra spark plug grounded against the block. I tried all 4 of my extra plugs and two different wires to assure it wasn't a fluke.
Chris
October 06, 2009, 10:45:18 am »
So you were trying to see the spark across the electrode while it was in the truck? Was this in daylight?
I generally put a screw driver in it and ground it against a body panel so I can see the spark jump.
Marc
October 06, 2009, 06:03:50 pm »
Pull the cap off and make sure the rotor is turning. Cam chain could be broken or roll pin could be broken or missing in the gear on the distributor.
werewolfx13
Site Supporters
October 06, 2009, 10:01:25 pm »
Once I've got the battery charged again, I'll double check to be sure the rotor is turning, I'm 99% sure it is, as its been in different locations each time I've taken the cap off. I used a plug grounded against my ground bolt on the passenger side of the motor at about 8:30 pm, so it was plenty dark, and there isn't even the faintest hint of a spark. Tomorrow evening I'm going to see if replacing the starter and trickle charging the battery full has corrected the slow starter, if it hasn't, I'm going to pull the distributor out and see if it cranks fine again. I know the distributor turned fine by hand before I put it in.
Chris
