Author Topic: A knocking sound  (Read 5335 times)
Offline 4x4Cowgirl
  • Country girls like it dirty
    • Facebook
A knocking sound
« on: October 05, 2009, 08:17:51 pm »
Well, I just got my truck, and this engine is supposed to be a fresh 350 with corvette heads.... I changed out the oil and spark plugs and did a tune up on it, and I still hear a knocking noise. I can't quite tell if its the actual motor that is knocking, (maybe a lifter) or if it's somethin else... It seems to be more significant when I'm on the gas... When I let off, it quitens down.. Has anyone had this problem before? Any help would be GREATLY appreciated!
Re: A knocking sound
« Reply #1 on: October 05, 2009, 08:20:05 pm »
A slightly loose lifter can sound like a knock.
Offline maddog
« Reply #2 on: October 06, 2009, 12:17:47 pm »
Does it make the knocking sound when it is cold as well when motor is at opperating temp.
Offline 4x4Cowgirl
    • Facebook
« Reply #3 on: October 08, 2009, 12:51:53 pm »
at operating temp.  Ive heard it could be the bearings?
« Reply #4 on: October 08, 2009, 02:03:29 pm »
Kinda hard to tell without hearing it but a mechanic's stethoscope will help you pinpoint the noise.
Offline maddog
« Reply #5 on: October 08, 2009, 02:10:40 pm »
Sounds like a rod bearing to me, on cold start it will be faint as oil heats up and thins out noise should get more intense, hold foot on break in gear and Little gas at same time, if noise increases it most likely a rod bearing if noise doesn't change could be a lose rocker (rocker/rod bearing are a difference sound )
Offline 4x4Cowgirl
    • Facebook
« Reply #6 on: October 08, 2009, 04:42:07 pm »
Alright thanks a lot guys  ;D
Offline oldwhity
« Reply #7 on: October 08, 2009, 06:04:43 pm »
I know it might be a shot in the dark but i'd also check for exhaust leaks.
Rob G.
81 Chevy K20 4x4 LWB stepside
« Reply #8 on: October 08, 2009, 08:10:37 pm »
i had my head gasket, header bolts back out a little and i thought i blew the motor. also you happen to know your comp. ratio?
