Body, Glass & Paint
help with LED lights
Topic: help with LED lights (Read 8395 times)
gold84gmc
October 13, 2009, 03:34:04 pm »
i just put in LED parking lights(in the front),brake/blinkers, and reverse lights, if i have the parking lights on and put the blinker on it doesnt blink, the light just gets brighter, but if i dont have the parking lights on they blink and work properly...does anyone know why they are doing this? and yes i have the correct bulbs for the blinkers
92 buick century custom 3.3L
Re: help with LED lights
October 13, 2009, 04:55:39 pm »
Most likely you need a HD flasher.
4x4x4x
85k10 diesel
October 13, 2009, 05:46:27 pm »
led lights have very little resistance compaired to std lights. you need a special flasher made for led lights.
please see this site for more info
http://www.superbrightleds.com/carbulb-notes.htm
hope this helps
85 k10 swb, 6.5 diesel. banks sidewinder turbo, 700r4, auburn gear ected limited slip/lockers f & r, 411 gears, front slotted disks, rear disk brakes, 4"exhaust, cibie headlight and fog lights, rancho rear spring lift, rancho shocks, new ft. springs,
October 13, 2009, 06:16:23 pm »
Actually you only need the HD flasher availible at any parts store. Use NAPA 552, we recommend those for the LED taillights we sell.
gold84gmc
October 13, 2009, 06:26:53 pm »
ok so i got a napa 552 and a napa 550...the 552 is smaller and have 2 terminals and the 550 is bigger and has 3 terminals...im guessing i should still use the 552?
October 14, 2009, 07:47:05 pm »
That is what we recommmend on the LED conversion kits we sell.
gold84gmc
October 14, 2009, 07:51:30 pm »
ok so im just gonna get some load resistors instead of trying to figure out which flasher will work
gold84gmc
November 12, 2009, 04:20:55 pm »
so now i have an electronic flasher and i got some resistors (50w 6ohm) 1 for each taillight, and the LEDs still dont work correctly....am i doing something wrong or will i just not be able to use them with my truck
beastie_3
Josh
November 12, 2009, 09:19:23 pm »
Have you tried swapping back to the regular bulbs to see if it is the LEDs actually screwing things up?
Semper Fi
gold84gmc
November 13, 2009, 05:31:10 am »
yes i have because thats the only way i can get blinkers when i have my lights on....i put LEDs for the front parking lights too, do i have to put resistors on those too?...right now i have LEDs in the front and regular in the back, and all of them work fine but when i put the lights on it thinks the front ones are blown because the blinker things on the dash stay lit up
gold84gmc
November 29, 2009, 07:44:51 am »
so do i need to put a resistor where ever i put an LED light?
Body, Glass & Paint
