Author Topic: Where can I find my motor info?  (Read 4904 times)
Offline JOKER
« on: October 16, 2009, 01:39:16 am »
I just bought this 87 Chevy 1 ton p/u. The problem I am having with this beast, is nothing is matching up. I have a steering pump bracket that only has 1 bolt holding it on and can not even tell anyone what year and size motor I have  :-[ .. So I can not find a replacement for it..
Also the fender emblem says deluxe custom 20, which I thought meant it was a 3/4 ton.  But I am having so much trouble matching up parts it is unreal..
I just temperarly replaced my brake pads (going to replace disc and rotors before putting on good pads.), they match up to 1/2 ton. abunch of other parts were matched up at 3/4 ton.. Is this normal?? Or did they old owners really mess this truck up??
Any advice would be great.
  Thanx. Joker.
Wanted to rebuild my dream truck. Looks like I'll be having just nightmares. LOL
Re: Where can I find my motor info?
« Reply #1 on: October 16, 2009, 04:31:53 am »
Post your vin # and do you have the spid label in the glove box?
Offline JOKER
« Reply #2 on: October 16, 2009, 10:10:58 am »
Well I got the vin# 1GCGR24KOHF375195, but there is no label on the glove box. Well there is no glove box. Some of the dash is missing.. LOL
Offline JOKER
« Reply #3 on: October 16, 2009, 11:32:57 am »
In fact where are all the numbers? Transmission do I need to pull it to find it? Motor ? ect? I see alot of forums with everyone knowing what they got. So I was wondering how I can find out mine. It would help me match up..
« Reply #4 on: October 16, 2009, 11:45:53 am »
1GC (US built) G (8001-9000 Hydraulic) R (1987-1991 2 wheel drive) 2 (3/4T) 4 (body type 2 door) K (350 V-8) O (check digit) H (1987) F (Flint MI built) the rest is the production #.
Offline JOKER
« Reply #5 on: October 16, 2009, 11:50:27 am »
  :o  WOW. THANK YOU. SO IT IS A 3/4 TON. WHAT ABOUT THE MOTOR? HOW DO I FIND OUT ABOUT IT? THEY MIXED AN MATCHED THIS TRUCK, I THINK.
Offline JOKER
« Reply #6 on: October 16, 2009, 11:57:41 am »
What I mean about the motor is what year? and how do I make sure it is a 350? The reason I ask is I think in the past someone has done a motor swap.
Like for example the power steering bracket does not even match up with the motor.
« Reply #7 on: October 16, 2009, 12:14:11 pm »
Under the alternator on the engine block is some numbers, post them.  If it is original to the truck with TBI on the back of the block is will have a 5.7 or 5.0 raised on the casting but are hard to see if still in the truck unless you have a small inspection mirror.
Offline JOKER
« Reply #8 on: October 16, 2009, 12:34:44 pm »
ohh This could take awhile.LOL . I will have to post pics of what a mess this thing is in.. LOL. Let me see if I can clean it up alittle and get back at ya..
Thank you soo far for the advice..
Offline JOKER
« Reply #9 on: October 16, 2009, 12:53:22 pm »
ok the only numbers I found was besides the firing order. was CFD207 That means it is a 305 right?
