Author Topic: Removing the stone guard from the bed side  (Read 17500 times)
Offline MarkS
« on: October 18, 2009, 08:19:17 pm »
Has anybody tried removing the urethane stone shield on the lower bed side. I have an orginal paint truck and would like to preserve the paint.
Re: Removing the stone guard from the bed side
« Reply #1 on: October 19, 2009, 12:37:43 pm »
Not without making a disaster. Why do you want to remove it? I'd leave it alone til you are ready to repaint.
Offline MarkS
« Reply #2 on: October 19, 2009, 01:00:41 pm »
That's what I thought... I was looing into this because the truck has great original paint with the exception of the yellowing urethane stone shields.
« Reply #3 on: October 19, 2009, 03:50:05 pm »
You could always overlay new ones
« Reply #4 on: October 19, 2009, 04:38:51 pm »
Is it dry and cracking or just discolored.  I removed mine but it was all dried up.  Used a heat gun, goo-gone and a plastic scraper.
Offline MarkS
« Reply #5 on: October 19, 2009, 08:21:39 pm »
There is some cracking and yelowing. Were you able to save your paint?
« Reply #6 on: October 19, 2009, 08:38:22 pm »
Yes, and it took at least 2 hours for EACH side:
Offline MarkS
« Reply #7 on: October 28, 2009, 08:44:32 am »
Anybody know where you can buy the stone shields? I know most don't want to replace them and I don't like the looks either but I'm trying to keep it true to original.
Offline oldredtruck
« Reply #8 on: October 28, 2009, 09:14:13 am »
check at local window tint shops - alot of them - at least here do it with some special 3m film - I guess its fairly common for these exotic car guys to get that stuff put down low on their cars for stone chip protection - I almost put em on old red but decided against it... I was scared off by the razor trimming they do to fit em on the vehicle...there is no template for most of that stuff.
85 shortbed...She digs it...
« Reply #9 on: October 28, 2009, 01:55:15 pm »
I can understand wanting to be original, but at some point you gotta draw the line.  Those chip guards will eventually dry up and crack again and look bad.
Offline gbskunk2006
« Reply #10 on: October 29, 2009, 12:30:55 am »
check at local window tint shops - alot of them - at least here do it with some special 3m film - I guess its fairly common for these exotic car guys to get that stuff put down low on their cars for stone chip protection...
I made the mistake of not replacing the stone guard last year when I finally got my truck back on the road.  Now I'm going to have to prep and repaint those sections on the bed but this time, I will definitely install some of that 3M film as protection from stone chips :)
86 GMC C15, 4.3 Litre V6, TH400
http://forum.73-87chevytrucks.com/smforum/index.php?topic=6879.0
90 Toyota SR5 4X4 Ext Cab V6 5 speed
99 Toyota Solara SLE
Offline thirsty
    • Suitor's Garage
« Reply #11 on: October 29, 2009, 06:43:17 pm »
Years ago I got some of the same material from a friend that worked at a GM dealership to put on the lower fairing of my street bike. He said they had it to put on vehicles that traveled on gravel roads alot. It was great stuff. I cut it to fit with scissors and just stuck it on. You couldn't see it and it worked perfect.
Offline SUX2BU99
« Reply #12 on: October 30, 2009, 10:23:33 am »
Those were factory applied? Interesting. Back in the day I saw alot of truck that had the aluminum add-on ones on there. Then years later I saw the rust that formed behind them   lol
« Reply #13 on: October 30, 2009, 10:45:10 am »
It might be worth checking with a dealer to see if they have a source for them still
