Author Topic: Tall Valve Cover  (Read 5256 times)
Offline snapdaddy
Tall Valve Cover
« on: October 18, 2009, 09:11:16 pm »
i have a 1980 c30 and i have the long style a/c compressor mounted on the driver side i really want to run the tall valve covers but after looking at my motor i realized that there is no room for them because of the a/c so i was wondering if i could switch it out for the smaller a/c compressor using different bracket or something like that  i tried to search but didn't really come up with anything and i don't really want to modify the brackets i have now... i need a new a/c compressor so if i could just switch them out that would work great
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: Tall Valve Cover
« Reply #1 on: October 18, 2009, 10:06:43 pm »
Welcome aboard Snapdaddy.
I have the 1.6 / 2.02 valves, tall valve covers in my 383 stroker in my '79 and have the long compressor.  I had to grind the rear compressor bracket a little, not for the clearance of the tall covers, but, for the edelbrock aluminum intake...i kinda notched it out just a little..not big deal.
« Last Edit: October 18, 2009, 10:23:29 pm by SgtDel »
Offline HAULIN IT
« Reply #2 on: October 19, 2009, 04:30:03 pm »
Welcome to the site! What engine is in your truck? Lorne
Offline snapdaddy
« Reply #3 on: October 19, 2009, 07:38:27 pm »
thanks for the replys
i have the 454 ill try and get a photo of what i am talking bout it seems like if i ran the tall valve cover i would have to trim off a lot of the bracket
« Reply #4 on: October 19, 2009, 07:42:17 pm »
You won't be able to run tall covers on a 454.  You could swap the front setup to the later style compressor
Offline snapdaddy
« Reply #5 on: October 19, 2009, 07:55:32 pm »
what would be need to do the swap
woud the a/c lines be the same what about the a/c brackets?  same or differnt
Offline snapdaddy
« Reply #6 on: October 19, 2009, 07:56:57 pm »
im going to the junk yard this weekend so i fi need diff bracket i can pick them up there
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
« Reply #7 on: October 19, 2009, 08:13:13 pm »
it seems as though you should be able to fabricate something quite easily, even if you need to get a different (longer) fan belt.  Get some angle iron, then weld the original bracket on top of that and drill two holes in the bottom part for the intake bolts...I could have some fun with that designing something.
