Author Topic: Captkaos - 1987 Hinge pins  (Read 4922 times)
Offline MarkS
« on: October 19, 2009, 12:58:53 pm »
Hi Capt,
I noticed on one of your posts you mentioned replacing hinge pins on a 1987 pick-up without removing the doors. Can you give me any pointers? I would rather not remove the doors and risk skinning up original paint.
Thanks!
Re: Captkaos - 1987 Hinge pins
« Reply #1 on: October 19, 2009, 03:40:58 pm »
Just pins or pins AND bushings?
Put a jack under the door and remove them one at a time.
Offline MarkS
« Reply #2 on: October 19, 2009, 08:01:11 pm »
It seems to make sense to replace both. Will the process work for either?
« Reply #3 on: October 19, 2009, 08:40:14 pm »
I have done it.
Offline squareboxguy
« Reply #4 on: January 21, 2010, 05:35:16 am »
How does the top pin come out? Looks like it would hit the door shell?
Offline dv8customs
« Reply #5 on: January 21, 2010, 02:14:54 pm »
Ran into the same problem with the top pin on mine. No way I could get it out with the door still on.
