Author Topic: Feul Injection ECM Questions  (Read 4019 times)
Offline 1HI4x4
  • V30 Crew now a shortbed.....
« on: October 22, 2009, 05:48:29 am »
I have a 1991 Crew Cab(square body) with throttle body injection(stock), I may be able to do a trade for a 1991 454 throttle body injection out of a 1 ton round body truck, will the ECM be the same or would they need to be swapped also? I know I would need a bigger radiator/exhaust fix, but what else would be needed? I was going to build a new carburated big block, but this just came up as a swap.
1988 V30 Crew Cab, Cummins power, 47RH-NP205, 8" lift, 13.50x35x20 Fuel Mudders on 20x14 XD Diesels -76 offset. Soon to be repainted, seats from a 2010 Lariat to be installed.
Re: Feul Injection ECM Questions
« Reply #1 on: October 22, 2009, 09:45:28 am »
Yes grab the computer and harness. It will make life much easier.
Offline 1HI4x4
« Reply #2 on: October 22, 2009, 12:24:06 pm »
That's what I thought.........
« Reply #3 on: October 22, 2009, 05:38:16 pm »
Get everything connected to it.  If you don't need it get rid of it.
