Author Topic: ***79 stepside 5.3l/4L60-E Swap***  (Read 119941 times)
Re: ***79 stepside 5.3l/4L60-E Swap***
« Reply #60 on: January 08, 2010, 02:15:36 pm »
There is only 1 crossmember for the trucks, for different transmissions, you just move it.
Offline Mtrhd329
« Reply #61 on: January 08, 2010, 08:09:33 pm »
using the stock crossmember just have to drill some new holes.  The keyless portion of my keyless chuck drill broke so i need a new one before i can get that finished.  I got my wiring hooked up and my fuse block and relay center installed.  Battery cables and radiator hooked up.  Also started messing around in HP tuners.
« Reply #62 on: January 08, 2010, 11:08:51 pm »
Be careful messing around.  You can really screw something up with it.
Offline Mtrhd329
« Reply #63 on: January 09, 2010, 01:03:17 am »
Mainly just reading and looking at all of the functions this program has not really anything to do yet as i havent fired the motor yet.
Any one know what manifolds fit the 73-87's I have been reading for hours and cant seem to find anything on 73-87s just 62-72s
F-body? vette? trailblazer?
« Reply #64 on: January 11, 2010, 04:22:16 pm »
LS manifolds?  I used the factory 6.0L manifolds.  If you get the later ones they should fit also (truck ones)
Offline 87OldYeller
« Reply #65 on: January 11, 2010, 05:20:52 pm »
header from summit part#  SUM-G908   $153.93 they are shorty headers fit 99-04 truck requires slight mods to PASS side rail, u can either cut the rail, or what i am going to do is take the header have it cut right above the flange and add about 2 inches of pipe in so it will clear.
Offline Mtrhd329
« Reply #66 on: January 11, 2010, 06:56:07 pm »
do these headers have egr provisions?  I am having a problem finding ones that fit but ALSO have egr.....might just need some made up but then they wont have a CARB EO# to pass smog
Offline 87OldYeller
« Reply #67 on: January 11, 2010, 07:15:54 pm »
that i do not know but member here aussie. he could tell you better i dont know what all he is running.
Offline fptransport
« Reply #68 on: January 13, 2010, 10:53:12 pm »
good build man.... I am about to start on mine. could you tell me where you found the info to make your harness work? I used to have a lot of links saved on my computer but I have a new one now so all I had saved was lost >:(  . but seriously nice truck
Offline 87OldYeller
« Reply #69 on: January 14, 2010, 11:45:19 am »
well u just have to kinda figure out what you need. I am gonna run stock exhaust so i am keeping 02 Sensors, i am going to get rid of EGR and all Evap stuff. don't know what else yet.but member here Aussie he is a huge help and has a ton of info he has his complete and running.
Offline Mtrhd329
« Reply #70 on: January 24, 2010, 12:25:18 pm »
so i got my manifolds to fit.  I cut the egr port off the stock manifold and welded a patch panel onto it.  Then i took the egr mounting base and made a flange and welded a pipe to it and that mounts just above where the stock egr mount was.  Now i have clearance.  Found that the rear of the manifold still rubs but i will notch the frame and clearance the manifold and i should be fine.  Everything still fit under the stock heat sheild so it looks factory still but i have my clearance.  Now on to the gas pedal and e-fans.
Offline Mtrhd329
« Reply #71 on: March 03, 2010, 07:59:44 pm »
So i got it to fire tonight turns out my PCM connector was not tightened down all the way.  I had been troubleshooting 3 different circuits for weeks and then i tightened the connector up and it fired right up.  Well now it is on to the last few things i need to tighten up or bolt on and then take it for a drive.  Started scanning with my HP tuners so i will be looking over the tune and seeing what i need to do from there.
« Reply #72 on: March 03, 2010, 08:05:29 pm »
sweet
Offline Jims86tpisub
« Reply #73 on: March 04, 2010, 03:11:19 pm »
Where did you get that killer deal on the drivetrain....Cali?
Jim
1986 K10 Suburban
Tuned Port Injection
193 Heads
Comp 260H cam
700r4 Raptor
Single exhaust with 2 Magnaflow Mufflers inline
Offline Mtrhd329
« Reply #74 on: March 04, 2010, 09:44:46 pm »
There is a local yard that sells motors and i talked him into selling everything for the swap.  now he has a listing on craiglist for swaps..lol
