th350 to th400 questions
Topic: th350 to th400 questions (Read 20068 times)
lmarinukjr
October 24, 2009, 08:58:58 am »
Ok first of all im extremely new to this so be gentle. I bought a 1980 pick up 4x4 and the trans went i call the guy i bought it from he told me it was a th400 in the truck so i bought one from a yard get it home and its a th350 in the truck. So i already have the trans and t-case. what else do i need to do the swap. Is there some kind of write up?
Re: th350 to th400 questions
October 24, 2009, 09:24:22 am »
You'll need to wire up the detent solenoid and get the switch that goes on the gas pedal.
oldredtruck
October 24, 2009, 10:18:12 am »
isn't their a diff in driveshaft lengths? If I remember correctly - I did a TH350 swap to a TH 400 a couple decades ago and had to have the driveshaft shortened by an inch and a half...so this would mean your driveshaft would need to be lengthened??? ( if I am reading this correctly.)
but my application was a pass car - so I don't know about the situation involving a T-case in the mix and how that affects things...
85 shortbed...She digs it...
lmarinukjr
October 24, 2009, 03:29:27 pm »
is there any write ups on this because like i said im completely new to this i dont know where to find the other parts or harnesses someone told me i have to move the crossmember and there is something about a vaccum module. the only thing i know is if i cant get this done in the next 2 or three weeks the truck is going to the scrap yard and the engine is going on ebay
October 24, 2009, 03:54:39 pm »
There's not much to it. It's a pretty straight forward swap. There is a single wire connector on the side of the trans. If you want proper automatic downshifts you hook up a wire to this blade terminal. That wire goes to a switch you buy at the autoparts store for your truck. The other end goes to your fuse panel. You already have a vacuum modulator on your TH350 so just hook up the same hose.
lmarinukjr
October 24, 2009, 04:39:08 pm »
my truck has a cable on it not vacuum.where does the switch go?the new trans has a vaccum hook up on the side where does that run? how do i move the cross member? is there another truck i can get the front and rear drive shafts from or do i have to get custom ones made?
Last Edit: October 24, 2009, 04:42:48 pm by lmarinukjr
October 24, 2009, 05:53:06 pm »
If you have a th350 you have a vacuum modulator and a detent cable. The Th400 has a vacuum modulator and a detent solenoid. Crossmember location should be the same. The mount may be different. Once you have it bolted in there you'll be able to see.
Here is a TH350 and you can see the vacuum modulator
Here is a TH400 and you can see the modulator
HAULIN IT
October 24, 2009, 06:28:15 pm »
I'm having a little trouble following your post without the punctuations & capitals, ect. Did you get the transfer case with the TH400? Is it the same looking as the one in your truck? If you have one gear & one chain drive you are going to have trouble with driveshafts for sure.
As Vile mentioned, the TH400 does not use the cable for passing gear, it uses a switch mounted on the gas pedal under the dashboard...you would need to get one, install it & run the wire. Both trannys use a vacuum modulator, both are on the Right side of the tranny, the TH350 is on the back corner & the TH400 is on the side (see Vile's pic. The Gold, round thing is the modulator) a manifold vacuum source is all you need to make that work.
As far as the crossmember, if you need to move it, just unbolt it & slide it, the holes should be there to re-attach it. Hope this Helps, Lorne
lmarinukjr
October 24, 2009, 08:10:01 pm »
The th400 came with a transfer case it doesnt appear to be the same. I understand im going to need a custom driveshaft. The switch that goes on the gas peda how does it attach? I dont see a vaccum module on the 350 thats in the truck. I was just asked by a friend if the 350 and 400 have the same shift pattern because he said it was reversed on the 2wd transmissions? is that true?
Donut
October 24, 2009, 09:06:35 pm »
There "should" be a vacuum modulator on the back of the trans (your old one).
Shift patterns are the same on all of them, (tbh350,400 2wd or 4wd)
'73 Chevy K-20 ***SOLD***
350/tbh350/np205
'86 C-30 dually, 454/tbh400
October 24, 2009, 09:49:30 pm »
Take a pic of your old trans for us.
lmarinukjr
October 24, 2009, 10:32:57 pm »
Its currently still in the truck as soon as i pull it out ill take a pic.
Lt.Del
Andy aka:SgtDel
DelbridgePhotography.com
October 24, 2009, 11:02:17 pm »
If it is a TH350 or TH350c, it has a modulator to adjust the shift points.
here's mine
www.DelbridgePhotography.com
www.HikerMania.com
www.delbridge.net/suburban
lmarinukjr
October 25, 2009, 12:54:46 pm »
OK so i just had another issue come up it may be bad but im not sure. I just ran the numbers on the trans i bought from the yard its out of a 88 chevy pick up not an 85 k5 blazer like i was told. Will this be a problem?
October 25, 2009, 05:29:27 pm »
No problem but you may have to swap the speedo gear in place of the VSS if was so equipped. Post a pic of the output where the speedo cable would go.
