Author Topic: cheap good headers?  (Read 25033 times)
Offline lbrowne
Re: cheap good headers?
« Reply #15 on: December 30, 2009, 09:00:43 pm »
I BOUGHT A SET FLOWTECH FOR $120.00 AT AUTO ZONE. I HAVE THEM FOR 5 MONTHS SOUNDS GOOD THEY HAVE NOT RUST BUT IM GOING TO USED HEADER WRAP FOR HEAT BUT THE DIFFENCE BETWEEN THE GOOD ONES & CHEAP ONES ARE THE DIFFERNCE GAUGE OF THE STEEL THEY USE.
Do yourself a favor and DO NOT use header wrap.
1986 GMC Sierra Classic
My first truck! (completely stock...for now)
« Reply #16 on: December 30, 2009, 09:04:13 pm »
Unless you are just running down the strip and rest I wouldn't recommend header wrap either
Offline Josh454
« Reply #17 on: December 30, 2009, 09:38:13 pm »
Flowtechs are some of the better ones out there for spark plug clearance too.
Offline derrick79
« Reply #18 on: December 31, 2009, 12:54:49 pm »
yeah summit doesn't have their own stuff, it is usually just all re-branded. i bought a set of summit headers for my 98 Z71 and when i got them, they were actually PaceSetter. Even the installation instructions were the PaceSetter instructions. however they were super cheap.
Offline bobcooter
  • 1979 Scottsdale C-20
« Reply #19 on: December 31, 2009, 08:43:36 pm »
I bought a set of the Summit headers and used the copper gaskets on my 79- 350. They fit well and I haven't had any leaks yet ( about 7000 miles on them). I painted over them with VHT black before I installed them. All the paint went up in smoke in about the first 10 to 15 minutes though. The primer has lasted pretty well though. I bought a Summit brand cam once and when I got it it was a Crane cam.
Offline bulldawg1081
« Reply #20 on: February 17, 2010, 12:04:40 pm »
not trying to hi-jack the forum but what about a good set of shortie headers? do you gain any performance with them or just with the long tube type? i just want something i can install and not have to modify my exhaust but gain a little power
1977 Chevrolet C10,gm goodwrench 350 engine,turbo 350 trans., 340 ratio 12 bolt rear.......1973 chevrolet C10,origional 350 converted to HEI,SM465 4 spd,307 ratio 12 bolt rear...
Offline jimbo
« Reply #21 on: February 18, 2010, 07:44:07 am »
I had shorties on my last truck.  Although I didn't dyno it, there was a decent gain.  I used them mainly to ensure that the collectors didn't hang low.
Offline 327power
« Reply #22 on: March 15, 2010, 06:19:20 pm »
Just bringing something up that was said earlier...whats wrong with header wrap?
LIVE FREE OR DIE
« Reply #23 on: March 15, 2010, 07:32:23 pm »
Voids the warranty and can distort the tubes, especially on thinner metal headers.
« Reply #24 on: March 15, 2010, 09:47:43 pm »
And it ends up rotting the tubes by holding moisture in.
Offline 327power
« Reply #25 on: March 16, 2010, 11:55:44 am »
Oh...ok. Just wondering because they look cool sometimes.
LIVE FREE OR DIE
Offline liftedchevys87
« Reply #26 on: March 27, 2010, 11:01:56 am »
I have the Summit $99 headers on a 78 chevy 454, they have been on there for 5 years with no problems ( I live in CT salty winters also )
- 87 1/2 ton 350 4x4
- 78 1/2 ton 454 flat bed 2wd
« Reply #27 on: March 28, 2010, 03:58:15 am »
I once read that
"Cheap, fast, reliable you can only chose two" and for most things I find it true
