Author Topic: In cab gas tanks for 81' C10?  (Read 12760 times)
Offline 327power
« on: November 01, 2009, 11:54:57 am »
Hi, has anyone ever heard of installing an in-cab tank in a 73-87 Chevrolet pick-up? Did they ever come in that pick-up?
Just curious because I really don't care for the crappy side mount tank. A rear mount would be cool too.
Thanks!
LIVE FREE OR DIE
Offline Grover 1
Re: In cab gas tanks for 81' C10?
« Reply #1 on: November 01, 2009, 12:29:38 pm »
Here is what I did to mine.  Cheaper and easier that a rear mount - uses the same tank just relocate the filler.  You don't want an in the cab tank.  People spend good money to get them out of the cab.
1978 C-10 SWB
1986 K-10 SWB
1975 C-10 SWB
And here I sit so patiently
You have to pay to get out of
Offline Grover 1
« Reply #2 on: November 01, 2009, 12:31:08 pm »
Here's another shot
1978 C-10 SWB
1986 K-10 SWB
1975 C-10 SWB
Offline campcrf
  • stroked
« Reply #3 on: November 01, 2009, 01:20:27 pm »
Grover....  thats a cool idea
« Reply #4 on: November 01, 2009, 07:52:53 pm »
So you would rather have explosive material behind you than outside the truck.
If you believing the hype about them being dangerous you have been mis-informed.
I moved my to the back using a Blazer tank, but for weight transfer.
see here: http://www.captkaoscustoms.com/blazertank.html
« Reply #5 on: November 01, 2009, 10:24:46 pm »
Looks good. What do you do when you have the bed full of crap though?  ;D
Why would you want to lose what little space you have behind the seat?
Offline Grover 1
« Reply #6 on: November 01, 2009, 11:26:19 pm »
I'm thinking that was in jest.. I never use it for hauling anything!
1978 C-10 SWB
1986 K-10 SWB
1975 C-10 SWB
Offline 327power
« Reply #7 on: November 02, 2009, 01:42:49 pm »
I always liked the in cab tanks. I had one in an old Ford a while ago. No problems. Besides, they won't rot out inside the cab! I really do not like the side tanks.
About that Blazer rear tank...is it a pain to install? It sounds kinda cool. Thanks!
LIVE FREE OR DIE
Offline 327power
« Reply #8 on: November 02, 2009, 02:49:31 pm »
What about a rear mount tank from an old F100 instead of the Blazer tank? A lot of the Fords had the rear tank and it might work if the frames are similar. You think? 8)
LIVE FREE OR DIE
« Reply #9 on: November 02, 2009, 04:36:04 pm »
The Blazer tank was a simple install you reuse what is already there and make it support piece from angle iron.  It is detailed on the link I posted.
Ford tanks don't use the same sending unit so you would have to modify it with a GM unit or swap fuel gauges.  The Blazer just bolts in and hooks up.
Offline 327power
« Reply #10 on: November 03, 2009, 07:26:02 pm »
Nah...I still want my in cab tank. So did they ever come in the 73-87 model line? The early 70's most likely.
LIVE FREE OR DIE
Offline Marc
« Reply #11 on: November 03, 2009, 08:11:58 pm »
I've never seen one and they will rot from the inside out, and it's not pretty.  And you get to hear the fuel sloshing around all the time!  Fun!
« Reply #12 on: November 03, 2009, 08:39:37 pm »
73 up never offered them.
I have had half a dozen pre 73 Chevy trucks with in cab tanks. Most of them were either allready rotted out and leaking when I got them, or started leaking while owned them.
You say you don't like the side tanks. Why?
Offline 327power
« Reply #13 on: November 04, 2009, 06:24:06 am »
I've never liked side tanks. It always had to be rear mount, the old in cab, or even a 5 gallon jug. 8)
LIVE FREE OR DIE
Offline bigblock73
  • Yeller
« Reply #14 on: November 04, 2009, 07:46:02 am »
gas smell, fuel sloshing around, lost storage, ugly filler neck on the cab...no thanks!  If you are dead set on an in cab tank, then 73-87's aren't for you.  :)  Buy a older Chev or Ford.
Jeff
'73 swb 2wd
73-87.com
