Author Topic: Summit Racing Chrome Pan.  (Read 5160 times)
Offline icecold
« on: November 02, 2009, 08:55:12 am »
I want a new oil pan, i can't use the summit orange painted because of dipstick location, used one on a previous truck it was great. So now i am thinking of the chrome oil pan since that is only $30 and it has correct dipstick location. Anyone had experience with a chrome pan, the chrome rear end covers have to be cleaned daily i think. I don't want an oil pan the same way. If i have to i will just sand my pan down and paint it.
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
Re: Summit Racing Chrome Pan.
« Reply #1 on: November 02, 2009, 12:51:22 pm »
I bought a 305 with one already installed. Put it in a 2wd truck and used it as a daily driver. It didnt leak but got filthy from road grime within a month
« Reply #2 on: November 02, 2009, 01:15:42 pm »
what year is your engine and where is the dipstick located?
« Reply #3 on: November 02, 2009, 08:21:02 pm »
Ive been told that chrome retains heat a little more than non-chrome...does it make a difference? probably not. You should still be able to get a stock painted pan for your block, pre-80 has dipstick on driver side. 80 and newer its on passenger side.
« Reply #4 on: November 02, 2009, 10:12:04 pm »
Auto Zone is the cheapest I have found for painted pans.
« Reply #5 on: November 08, 2009, 04:57:11 pm »
Heat goes to less heat. So the cooler the surface is the more thermal energy it will extract.
Offline werewolfx13
« Reply #6 on: November 09, 2009, 12:01:55 am »
Old trick used on iron steam heat radiators, if you have to use a radiator with too little iron for a given location, you can increase its efficiency by painting it flat terra-cotta. The same holds true for air cooled motorcycle engines, flat black and terra cotta both accelerate the transfer of heat. Silver and other reflective colors actually reduce the efficiency.
Chris
'83 Chevy c10 Silverado SWB
