Author Topic: porting heads suggest  (Read 4192 times)
Offline fabioblazer
« on: November 08, 2009, 04:33:47 am »
Hello guys!
I must remove heads from my '81 k5 Blazer 305 engine, 'cause i must replace old lifters with new ones OE.
I'm thinking that it could be a good thing check-out heads for crack or damage and doing "porting heads".
With "porting heads" process, which other process it's important?
if i improve air flowing, intake manifold must be replaced with better new?
or for example with new exhaust manifold?
If air runs better but it's blocked by tight exhaust manifold, i think could be just an hald good job.
Thanks guys for attention.
Fabio
Re: porting heads suggest
« Reply #1 on: November 08, 2009, 06:37:15 am »
Why are you replacing the lifters? I wouldn't waste my time porting 305 heads unless I did some significant engine mods.
Offline krazylunatic
« Reply #2 on: November 08, 2009, 11:27:12 am »
ive heard the price of having port work and all done by a shop is close to the same cost wise as just buying an aftermarket set
« Reply #3 on: November 09, 2009, 01:30:11 am »
like vile said i don't know about a 305 but if you were to do it you should get your manifolds exhaust and intake ported and matched with it all and i would also go with headers to help out a little. and aftermarket intake
Offline HAULIN IT
« Reply #4 on: November 09, 2009, 09:09:18 am »
Fabio, Welcome to the site! I also agree with the others...Don't bother. By the way, you do not need to remove the heads to replace the lifters, I also question though...Why must you replace the lifters? Lorne
« Reply #5 on: November 09, 2009, 03:56:59 pm »
If you are replacing the lifters because of wear, putting new ones on a used cam will not fix anything.
