Author Topic: dullie rim  (Read 5631 times)
Offline heyharris1
dullie rim
« on: November 10, 2009, 12:40:02 pm »
hello all,
just a quick question i put stock steel dullie front wheels back on my truck, the problem is i have been told there is supposed to be a ring that goes between the wheel and the lug nuts. the lug nuts are kinda tapered but the wheels are not. am i on drugs or should there be a ring that is placed there like a compression ring or something.
thank you all
jim
Offline frogman68
Re: dullie rim
« Reply #1 on: November 10, 2009, 12:54:56 pm »
My dually has the ring its about a 1/8 to a 1/4 thick has the 8 holes for the lugs and two tips on it (guess to grab it) you will need it to keep the wheel secure.
Offline heyharris1
Re: dullie rim
« Reply #2 on: November 10, 2009, 01:33:46 pm »
any way you could check for a part number or know where i could get some at
thank you
jim
Offline 79K20
Re: dullie rim
« Reply #4 on: November 10, 2009, 03:33:22 pm »
Yes you need the ring. Do not install the wheels without the ring.
It's there because the lug holes aren't tapered (as you already noted). Otherwise both faces of the rim face would need to be tapered in order to work on both the front and rear axles.
I'm pretty certain you can get the 8-lug rings from GM still. Otherwise try a junk yard.
Offline heyharris1
Re: dullie rim
« Reply #5 on: November 11, 2009, 08:40:14 pm »
guess i need to call the dealer cause i cant find anybody else who sells them. should not cost to much.
