Author Topic: removing AC  (Read 7564 times)
Offline 84chevysilverado
removing AC
« on: November 16, 2009, 08:07:09 pm »
Im removing the whole AC system on my 84 chev and i was wondering if il run into any problems with my heater if i remove the AC. so far iv removed the compressor and all the lines but im not sure if the big box on the firewall is connected to th heater system some how? anyone done this before? thanks marc
Re: removing AC
« Reply #1 on: November 16, 2009, 08:11:20 pm »
A lot of us have for one reason or another. I relocated my resistor, relay and all of the associated wiring into the cab. I used an AC delete box.
Re: removing AC
« Reply #2 on: November 16, 2009, 08:12:50 pm »
Vile, got any more info on that AC delete box?
Re: removing AC
« Reply #3 on: November 17, 2009, 07:02:59 pm »
Re: removing AC
« Reply #4 on: November 17, 2009, 07:06:08 pm »
Sweet, thanks!
Offline eisenhauer01
Re: removing AC
« Reply #5 on: November 17, 2009, 07:28:27 pm »
thats awesome. I just removed my whole ac system from my truck, even the dryer.. now i just have the pipes coming from the evaporator core sticking out of the air box..
but low and behold here comes  vile,  you are the man. you have all the answers.
1986 K10 Short Bed 4x4 305
Re: removing AC
« Reply #6 on: November 18, 2009, 04:59:05 pm »
ok thanks il take the whole ac system out gonna sell the factory original compressor still worked before i took it out. thanks again guys
Re: removing AC
« Reply #7 on: February 11, 2010, 06:16:17 pm »
Sorry to bring up an old post, but figure it would be better to add to one rather than start a new one.
Anyways, I got my AC delete box and its all mocked up, ready to install. I will probably just mount the relay on the firewall, but Im not sure what to do with the resistor. I dont know if I want to get a non ac resistor or just use the one I have. I also havent figured out where I want to mount it. I dont think the box is thick enough (as in overall dimension, not thickness of the fiberglass) to mount it the way it was before because the resistors are pretty long. I would love to see some pics of what you have done or at least a good description. I have searched and wasnt able to find anything. After Im done, Ill post pics to help others out in the future.
Re: removing AC
« Reply #8 on: February 11, 2010, 11:34:47 pm »
I mounted mine on the inside in the top of the case. Just be careful that it doesn't touch anything like the heater core. I'd also be very careful if you get leaves and debris in your cowl, as if anything touches it it can easily ignite.
Re: removing AC
« Reply #9 on: March 01, 2010, 12:13:04 pm »
Your talking about the interior side? The box that has the vent cables?
What did you do with the two holes the core tubes fit through? It was all sealed up before with sealant, but now the holes are fully exposed since the AC delete routes under them. I wouldnt be too worried about it, but there is that angled lip that aims straight for them that will pour water in that area.
Re: removing AC
« Reply #10 on: March 01, 2010, 09:22:22 pm »
Use Butyl tape (dumdum)
