Author Topic: Leveling Question?  (Read 7847 times)
Offline okiesinmt
Leveling Question?
« on: November 16, 2009, 08:36:47 pm »
I've got a 75 K10 and I just want to level it.  What is the easiest way to do so?  Its all stock suspension currently.
Thanks,
Sean
Re: Leveling Question?
« Reply #1 on: November 16, 2009, 09:42:58 pm »
I assume its higher in the back, but let us know for sure as well as what the height difference is at each end.
Offline okiesinmt
« Reply #2 on: November 16, 2009, 10:24:39 pm »
center back fender well is @35", center of front fender well is @34".
Sean
« Reply #3 on: November 16, 2009, 11:31:34 pm »
What are your plans for the truck? Is a lift kit somewhere in the future? What is the truck used for?
« Reply #4 on: November 16, 2009, 11:54:58 pm »
you could just take a leaf out of the rear that will drop it down
Offline okiesinmt
« Reply #5 on: November 17, 2009, 01:29:29 am »
No lift plans for the future, I would like to keep it as stock as possible with a touch of personalization as comfortable to ride in as possible.  Its not a daily driver, more of a toy  all the excitement is under the hood, kind of a sleeper if you will.  Just want to lower the back end a touch, maybe get the weight transfered a little more to the back.
Sean
Offline 1980c10
« Reply #6 on: November 19, 2009, 04:24:33 am »
u could get 2" drop shackles for the rear or just remove a leaf. the shackle will move the rear of the spring up 2 inches lowering the back of the truck about an inch. they are not expensive and are easier than removing a leaf. however if you would like to soften up the ride then you should remove a leaf.
Offline okiesinmt
« Reply #7 on: November 19, 2009, 10:17:50 pm »
thanks for the replies, how do the drop shackles effect the ride?
Offline fitz
« Reply #8 on: November 20, 2009, 12:12:45 am »
  I went through this problem when I installed the lift kit in my truck. After trying 3 different sets of front springs to level it out I had a friend make up a set of custom length front spring hangers. If I remember correctly they are about 3/4" - 1" longer than the stock hangers and help level it out. Once installed on the truck it would take a good eye to notice them.
  Keep in mind these trucks never really looked perfectly level from the factory.
Offline 1980c10
« Reply #9 on: November 20, 2009, 10:30:54 pm »
the drop shackles won't affect the ride. also if you don't like it u can just put the originial back in.
