Author Topic: Dual to quad headlights = Better lighting?  (Read 15251 times)
Offline Flashback
« on: November 20, 2009, 05:01:59 pm »
So I am interested in doing the quad headlight upgrade, but only if it provides better lighting, as in, brighter, better beam pattern, etc. If you have done the conversion post here and let me know!
1983 Malibu Wagon|TPI 305|T5 5 speed|3.73 non-posi
1992 Honda Accord Wagon|SOHC|5 speed|Gude Cam
1986 Chevrolet C10|305 V8|SM465|Shortbed|Custom Deluxe
Offline Marc
Re: Dual to quad headlights = Better lighting?
« Reply #1 on: November 20, 2009, 07:39:34 pm »
Light seems better, I also upgraded the wiring and put lamps in out of a Dakota...2E1 - they are brighter as well.
Offline joesgarage71
  • Wrench
« Reply #2 on: November 21, 2009, 04:13:09 pm »
if your not getting 12 volts to your lights you can add a relay to the harness
Offline Mr Diesel
  • Aaron
« Reply #3 on: November 21, 2009, 09:09:24 pm »
You also could just get some off-road lights and mount them to your bumper. Use a relay and wire it into your high-beams. Just point them low enough that they aren't obnoxious.
1976 C20 Crewcab, 6.2L/SM465
1983 C30, 6.2L/TH400
1983 K30 Crewcab 454/700R4
Offline Flashback
« Reply #4 on: December 16, 2009, 09:07:03 pm »
Thanks for the replies guys.
I was on the highway a few weeks ago at night and passed a blazer with the quad lights, defiantly alot brighter. I will perform this upgrade should I find a rad support cheap enough.
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
« Reply #5 on: December 30, 2009, 04:23:33 pm »
On my 94 z71 I removed the composite headlights and put the quad glass headlights on and wow what a huge difference.
« Reply #6 on: December 30, 2009, 04:31:44 pm »
I am going to do it, the good thing is brights can be adjusted as needed.
Offline dirtracer81_2
« Reply #7 on: December 31, 2009, 09:20:24 pm »
Well my truck is basically completely dissasembled so im gonna go ahead and make the change...My dad had an old support laying here thats pretty decent but I have to buy a set of headlights and im gonna cut the harness out of a rust bucket he has. I like the look of them but I really dont know if it would be worth the trouble doing it if you have one together.
Offline chevyman72
  • 1987 C10 2WD 350cid 700r4
« Reply #8 on: January 01, 2010, 11:16:42 am »
you will have to change your radiator support. to do it right.
Chevyman
« Reply #9 on: January 01, 2010, 01:30:36 pm »
You shouldn't have to cut any wires. Just unplug the head light harness from the back of the fuse box / bulkhead connector.
Offline Laderhosen
« Reply #10 on: January 01, 2010, 03:11:20 pm »
I've just done this on my truck, and I think the lights are much better now. Looks much better too.  :)
'82 3/4 ton, 350, th400,
'88 K5 Blazer, 350, 700R4
’98 BMW 328i daily drive
Offline chevyman72
« Reply #11 on: January 02, 2010, 02:22:52 am »
Blazin is right about the wire harness
Chevyman
