Body, Glass & Paint
Dual to quad headlights = Better lighting?
Topic: Dual to quad headlights = Better lighting? (Read 15258 times)
Flashback
November 20, 2009, 05:01:59 pm »
So I am interested in doing the quad headlight upgrade, but only if it provides better lighting, as in, brighter, better beam pattern, etc. If you have done the conversion post here and let me know!
1983 Malibu Wagon|TPI 305|T5 5 speed|3.73 non-posi
1992 Honda Accord Wagon|SOHC|5 speed|Gude Cam
1986 Chevrolet C10|305 V8|SM465|Shortbed|Custom Deluxe
Marc
Re: Dual to quad headlights = Better lighting?
November 20, 2009, 07:39:34 pm »
Light seems better, I also upgraded the wiring and put lamps in out of a Dakota...2E1 - they are brighter as well.
joesgarage71
Wrench
November 21, 2009, 04:13:09 pm »
if your not getting 12 volts to your lights you can add a relay to the harness
Mr Diesel
Aaron
November 21, 2009, 09:09:24 pm »
You also could just get some off-road lights and mount them to your bumper. Use a relay and wire it into your high-beams. Just point them low enough that they aren't obnoxious.
1976 C20 Crewcab, 6.2L/SM465
1982 K30 Crewcab , 427TD/TH400
1983 C30, 6.2L/TH400
1983 K30 Crewcab 454/700R4
1986 K10 350/400. 1989 K30 cab/chassis 454/SM465
Flashback
December 16, 2009, 09:07:03 pm »
Thanks for the replies guys.
I was on the highway a few weeks ago at night and passed a blazer with the quad lights, defiantly alot brighter. I will perform this upgrade should I find a rad support cheap enough.
dumbucket1
Too Many Trucks
Coal Hauler
December 30, 2009, 04:23:33 pm »
On my 94 z71 I removed the composite headlights and put the quad glass headlights on and wow what a huge difference.
zieg85
December 30, 2009, 04:31:44 pm »
I am going to do it, the good thing is brights can be adjusted as needed.
dirtracer81_2
December 31, 2009, 09:20:24 pm »
Well my truck is basically completely dissasembled so im gonna go ahead and make the change...My dad had an old support laying here thats pretty decent but I have to buy a set of headlights and im gonna cut the harness out of a rust bucket he has. I like the look of them but I really dont know if it would be worth the trouble doing it if you have one together.
chevyman72
1987 C10 2WD 350cid 700r4
January 01, 2010, 11:16:42 am »
you will have to change your radiator support. to do it right.
Chevyman
Blazin
Blazin new trails!
January 01, 2010, 01:30:36 pm »
You shouldn't have to cut any wires. Just unplug the head light harness from the back of the fuse box / bulkhead connector.
Laderhosen
January 01, 2010, 03:11:20 pm »
I've just done this on my truck, and I think the lights are much better now. Looks much better too.
'82 3/4 ton, 350, th400,
'88 K5 Blazer, 350, 700R4
’98 BMW 328i daily drive
chevyman72
January 02, 2010, 02:22:52 am »
Blazin is right about the wire harness
Chevyman
Body, Glass & Paint
