Author Topic: back glass rubber  (Read 5008 times)
Offline screamin86
back glass rubber
« on: November 21, 2009, 01:09:53 pm »
So im swaping out my slider for a soild back glass. My question is are the seals the same between the windows? Mine looks to have been replaced and is in great shape and if i dont have to have the down time waiting on a new seal that would be great. Any and all fast replys are welcome! Thanks guys and gals.
86 ta:lm7 hot cam boltons
Re: back glass rubber
« Reply #1 on: November 22, 2009, 01:13:06 am »
the size of the window its self is the same but the style of the seal are diffrent in some years but it they will swap out
« Reply #2 on: November 22, 2009, 11:46:37 am »
I found that GM sliders use the same size gasket.  Aftermarket ones do not.
Offline screamin86
« Reply #3 on: November 22, 2009, 10:10:35 pm »
Im not 100% sure but mine looks to be original but its tinted and i believe my rpo code sheet says slider but not completely sure. Was maily wondering cause the seal looks awful wide in the channel where the slider is.
Offline 1980c10
« Reply #4 on: November 23, 2009, 04:31:39 am »
i would def. go with a new gasket. the slider is going to be wider where the glass slides. you also might get some wind noise and water leaking. a new gasket might also make it easier to install
Offline SUX2BU99
« Reply #5 on: November 30, 2009, 10:41:56 am »
I had mine swapped out just 2 months ago from a slider to a solid I got from a regular glass shop. New one went in with the old seal no problems. I had the glass guy do it and he didn't have any problems either.
