Author Topic: holley carb and edelbrock intake  (Read 22658 times)
Offline 305chevy c-10
« on: November 22, 2009, 02:51:44 pm »
hey i have a 600-650 holley  carb and a edelbrock performer intake .im putting this on a stock 1985 c10 w/t 305 will this give my engine more torque...or simply just drink more gas .......just trying to get more low end torque from a 305 with out investing alot in such a small motor
Heartbeat of America yesterday's cheverolet
18T5C10
Re: holley carb and edelbrock intake
« Reply #1 on: November 22, 2009, 07:25:33 pm »
You won't gain anything noticeable as far as power in my opinion.  If you want more power you need to do a cam swap along with the associated pieces to make more power.
« Reply #2 on: November 22, 2009, 07:42:46 pm »
 :(...........thanks cap .so much for that ....well what do you suggest for a cam that would be ok with stock converter
18T5C10
« Reply #3 on: November 22, 2009, 10:35:24 pm »
Your best bet would be a new rear gear ratio
Offline Stewart G Griffin
« Reply #4 on: November 22, 2009, 11:33:20 pm »
i'm with VZ on the diff ratio.
Also, i think headers are cheap way to more torque.  i think edlebrock has something that will bolt in, but i'm too tired to look it up.
Offline malibu795
« Reply #5 on: December 01, 2009, 08:54:10 pm »
a good 1 1/2" tube header will work nicely on a 305
the performer cam that edelbrock sells works nicely as well
adam wildman
75 K25 383/400
Offline jimbo
« Reply #6 on: December 03, 2009, 09:58:04 pm »
I disagree, with a decent exhaust the intake alone should help a bit and the holley is more tunable than the q-jet, I would definitely go for it.  Although an intake swap is a perfect time to swap that dead fish of a cam in that 305 if you are going to do it.
Offline jimbo
« Reply #7 on: December 03, 2009, 10:01:23 pm »
Here is a good read:
305 BUILD-UP PART 1.
Car Craft started out with an 80,000 mile (130,000km) 305 LG4 engine from a 1982 Camaro. They removed the engine from the Camaro and put it straight on the dyno with headers, 3" dual pipes to Flowmaster mufflers, and a HEI distributor with 22 deg total advance. This gave a baseline dyno result of:
197 HP @ 4,000 rpm. 261 ft/lb torque @ 3,100 rpm.
305 BUILD-UP PART 2.
Added an Edelbrock Performer EGR intake manifold, but with the EGR blocked off.
217 HP @ 4,200 rpm. 285 ft/lb torque @ 3,300 rpm.
This is an increase of 20 HP and 24 ft/lbs over stock.
305 BUILD-UP PART 3.
Replaced Edelbrock Performer EGR intake with an Edelbrock Victor Jr single plane intake manifold. Replaced Q-Jet carb with a 750 Holley double pumper.
This resulted in no change from the previous mods, maintaining the increase of 20 HP and 24 ft/lbs over stock.
305 BUILD-UP PART 4.
Added Comp Cams XE262H-10 "Xtreme Energy" hydraulic flat tappet cam. 218/224 dur @ 0.050, .462/.469 lift, 110 deg LS. Set initial timing to 16 deg BTDC.
270 HP @ 5,100 rpm. 291 ft/lb torque @ 3,800 rpm.
The cam change resulted in a huge increase of 53 HP. Torque was up by 6 ft/lbs.
305 BUILD-UP PART 5.
Replaced stock cylinder heads with World Products 305 S/R Torquer heads.
298 HP @ 5,500 rpm. 308 ft/lb torque @ 3,900 rpm.
A 28 HP increase over the stock heads, and the 305 engine now has close to 300 HP.
305 BUILD-UP PART 6.
Replaced World Products 305 S/R Torquer heads with '96 - '97 Chevy truck L31 Vortec cast iron heads, GM P/N 12558060. These are available from GM dealers in the USA for US $408 a pair, fully assembled. The Vortec heads require a different intake manifold, and Car Craft chose an Edelbrock Super Victor. They kept the same Holley 750 DP. Car Craft says that these heads are a bolt on for conventional small block Chevy engines. If your engine is earlier than '87, you will also need a set of self aligning rocker arms, and a pair of "center-bolt" valve covers.
325 HP @ 5,800 rpm. 317 ft/lb torque @ 4,800 rpm.
TECH COMMENTS
With peak torque at 4,800 rpm, the 325 HP 305 would definitely need some stiff rear end gears (I'd suggest a minimum of 3.73 ratio) plus a high stall converter if the car had auto trans. In my opinion the WP Torquer heads are the better choice for a street engine. I think that a 300HP 305 with 308 ft/lbs at 3,900 rpm, would be a nice street / strip combination.
Offline Jim Rockford
  • Banned
« Reply #8 on: December 10, 2009, 08:20:26 pm »
you will never beat a good Qjet for performance and fuel economy.
1973 k20 Camper special
1980 k20 custom deluxe
2004 Crown Vic LX sport
Offline malibu795
« Reply #9 on: December 11, 2009, 10:33:30 am »
if you can get it tuned properly and keep it tuned..
the performer series and AVS thunder series share alot of similairity with a Q-jet
adam wildman
75 K25 383/400
Offline jimbo
« Reply #10 on: December 11, 2009, 12:32:00 pm »
I completely disagree.  I have had some qjets and even a speadbore holley that have done very well, but none of them have ran as well or gotten as much mpg as some of my squarebore holleys.
« Reply #11 on: December 11, 2009, 05:41:40 pm »
It's all in how you tune em
Offline jimbo
« Reply #12 on: December 14, 2009, 10:43:46 pm »
