Author Topic: Power Steering any one?  (Read 14315 times)
Offline gim_bob
  • R.I.P. Dime
« on: November 24, 2009, 11:27:29 am »
Ok, I'm fixing to buy a 74 step side, and it doesn't have power steering yet. It is 2wd, with a 350. On a scale of 1-10, how difficult is it to add power steering and how much money am I looking at.
I aint as think as you drunk I am!!
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: Power Steering any one?
« Reply #1 on: November 24, 2009, 01:10:12 pm »
i took a '70 firebird with manual steering and put in  a 400 sbc, 4spd muncie, and, a power steering unit donated from a '76 trans am.  If I remember correctly for that, I simply had the pump/brackets/hoses and the steering unit and simply bolted them in place.  It was quite easy. The steering column linkage was a simple bolt up to the hydraulic unit.
« Reply #2 on: November 24, 2009, 02:42:44 pm »
Super easy, I would say
Offline oldredtruck
« Reply #3 on: November 24, 2009, 03:54:54 pm »
CAKE AND PIE!!!
 see if you can find a steering box from an 82 - up camaro/firebird - it's a direct replacement but the ratio is quicker...what I did anyway
85 shortbed...She digs it...
« Reply #4 on: November 24, 2009, 03:55:43 pm »
Box, pump, hoses and fluid
Offline gim_bob
  • R.I.P. Dime
« Reply #5 on: November 24, 2009, 07:26:03 pm »
Thank you gentlemen, i appreciate it.
« Reply #6 on: November 24, 2009, 09:50:57 pm »
Make sure the crank pulley has the extra grooves for the power steering set up.
Offline SUX2BU99
« Reply #7 on: November 25, 2009, 05:09:55 pm »
CAKE AND PIE!!!
Now there is an interesting idea!
« Reply #8 on: November 30, 2009, 12:25:03 pm »
The F-Body boxes don't mount like a truck box.
Offline team39763
« Reply #9 on: November 30, 2009, 11:05:43 pm »
Any more ideas on this topic?  What other boxes would fit our trucks?
« Reply #10 on: December 01, 2009, 12:42:31 pm »
From all my research for the past 30 years there is no box that will fit other than the one that is on it.
Offline gim_bob
  • R.I.P. Dime
« Reply #11 on: December 01, 2009, 08:16:48 pm »
Is it specific to which year the truck is, as in not 73-87
« Reply #12 on: December 01, 2009, 09:38:02 pm »
2wd and 4wd is different along with changes over the years. The steering shaft couplers were different as were the steering columns at the base.
« Reply #13 on: December 01, 2009, 09:49:34 pm »
There are hose differences made as well, the newer models used o-rings.  Best to use as close to your year as possible.  I still like armstrong steering myself. No power steering boxes that leak, or belts that squeal.
« Last Edit: December 02, 2009, 10:45:20 pm by zieg85 »
« Reply #14 on: December 02, 2009, 01:10:23 pm »
hoses are split 73-80 and 81-87(91) The 80's are hit miss of if they are o-ring or not.
