Author Topic: ? about front drop  (Read 5249 times)
Offline kustom71
? about front drop
« on: November 26, 2009, 11:22:26 am »
HAPPY THANKSGIVING!
I have an 86 lwb c-10 and have already installed a bell tech flip kit
Mow Im about ready to do the front but im not sure how much of a drop I will need to get it even with the back
Will it need 3inch spindles only,or drop spindles and springs?
Is there anyway I can figure out what I will need?
And if it needs spindles and springs should I use the biggest drop spindle to keep steering correct or spilt the difference in spindle and spring?
Thanx
Re: ? about front drop
« Reply #1 on: November 26, 2009, 02:42:26 pm »
Take a tape measure and see how far you want the front to come down.
Offline biscuit41
« Reply #2 on: November 26, 2009, 06:47:33 pm »
Did you have some rake before?  The back is generally 2'' higher than the front in stock form.
1985 C10 Longbed
Offline kustom71
« Reply #3 on: November 26, 2009, 08:21:25 pm »
Guess you can tell I got alot of things on my mind
I sat here all day thinking about it and never even thought of just taking the wheels off and lowering it on the jack while measuring
Thanx
Yes It did have a slight rake I will try measuring tomorrow
Thanx again!!!!!!!!!!!!
