Can't find a HP PS Hose for my Blazer
Topic: Can't find a HP PS Hose for my Blazer (Read 10361 times)
LUV2XCLR8
December 04, 2009, 05:09:54 pm »
My 81 has a serp set-up, so does my 72, but I can't find
the line anywhere? Nothing I find looks like what I have?
Anybody have any ideas on what I can do? Thank you
72 PROJECT:
"YFTSB"
81 DRIVER:
"GLACIER"
Re: Can't find a HP PS Hose for my Blazer
December 04, 2009, 05:13:43 pm »
Autozone?
LUV2XCLR8
December 04, 2009, 05:21:34 pm »
81 never came with serp set-up. I have spent hours
at numerous stores trying their patience and nothing.
I can't find anything that looks like what I have on it.
*A custom one made from Summit is around $70.00
Last Edit: December 04, 2009, 05:33:35 pm by LUV2XCLR8
72 PROJECT:
"YFTSB"
81 DRIVER:
"GLACIER"
HAULIN IT
December 04, 2009, 05:37:46 pm »
Can you post a pic or Two of the engine, power steering pump, ect.? Maybe someone can Identify it. Is this a factory looking set-up on some year vehicle or A/M stuff? Lorne
LUV2XCLR8
December 04, 2009, 05:45:43 pm »
Aftermarket GM serp set-up on my 72 Blazer.
PS box fittings are the same on as on my 81.
Pump end we think is a 14mm x 1.5 w/ o-ring
Box end should be a 5/8-18 w/ out an o-ring
72 PROJECT:
"YFTSB"
81 DRIVER:
"GLACIER"
December 04, 2009, 05:50:56 pm »
http://www.autozone.com/autozone/catalog/parts/partsProduct.jsp?skuDescription=Duralast+/+Power+Steering+Pressure+Line+Hose&categoryDisplayName=Suspension+%26+Steering&fromString=&itemIdentifier=217059_0_11713_&productId=217059&sortType=null&parentId=46-0&filterByKeyWord=&isSearchByPartNumber=&navValue=14602103&categoryNValue=&fromWhere=null&itemId=2103-0&displayName=Power+Steering+Pressure+Line+Hose&store=5152&searchText=&brandName=Duralast
LUV2XCLR8
December 04, 2009, 05:55:45 pm »
Wowsers, you guys are quick on the fly using serches
Do you think I can bend that straight end w/ out kinking it?
Nobody in my town has it for me to even test fit this
Last Edit: December 04, 2009, 06:04:33 pm by LUV2XCLR8
72 PROJECT:
"YFTSB"
81 DRIVER:
"GLACIER"
LUV2XCLR8
December 06, 2009, 04:23:48 am »
I found one, but it's o-ring on both ends, can it be modified?
72 PROJECT:
"YFTSB"
81 DRIVER:
"GLACIER"
December 06, 2009, 05:39:55 am »
my 79 had the flange type and my 86 has the o ring type. i pulled the engine out of my 86 to put in my 79 ran into that problem then i just switch PS pumps and that was done. might be easer to go to the junk yard and grab a newer style
LUV2XCLR8
December 06, 2009, 08:47:52 am »
I thought of that, but everything is brand new
72 PROJECT:
"YFTSB"
81 DRIVER:
"GLACIER"
December 06, 2009, 09:57:01 am »
you might be able to get someone to make one for you or combine the two
December 06, 2009, 10:10:29 am »
What exactly do you need?
zieg85
December 06, 2009, 11:11:45 am »
Take the fitting out of a newer pump that takes the 0-ring type and put it in yours. I have done it many times.
LUV2XCLR8
December 06, 2009, 04:28:33 pm »
Are you talking about a Box fitting? Where can I get one of those?
72 PROJECT:
"YFTSB"
81 DRIVER:
"GLACIER"
zieg85
December 06, 2009, 04:43:55 pm »
I am talking about the hp fitting on the pump. I think it takes a 1 inch wrench. I can take pics tomorrow if you need them, I know I have pumps in my shed.
