Author Topic: just a question  (Read 14321 times)
Offline gotmud
    • county4x4.com
just a question
« on: December 11, 2009, 08:51:01 pm »
well i just twisted the rear shaft on my truck yesterday it is only a 10 bolt now i have a chance to buy a 1956 eaton HO72 rear end for dirt cheap what do you guys think of those axles ?? oh it is going in a 86 K10 4x4
it's all fun and games till someone looses an oilpan
Offline gotmud
    • county4x4.com
Re: just a question
« Reply #1 on: December 11, 2009, 08:52:38 pm »
or should i just fix the ten bolt ? thanx
Offline joesgarage71
  • Wrench
Re: just a question
« Reply #2 on: December 11, 2009, 10:10:31 pm »
 Just fix the 10 bolt
Re: just a question
« Reply #3 on: December 13, 2009, 01:11:39 pm »
Fix the 10bolt.
Offline Russ130
Re: just a question
« Reply #4 on: December 13, 2009, 07:16:12 pm »
or find a 14 bolt out of a 3/4 or 1 ton
Offline gotmud
    • county4x4.com
Re: just a question
« Reply #5 on: December 13, 2009, 07:41:01 pm »
thanx for all the replys i take it you's don't really like HO72's i have heard that they were the same as the 14 bolts and they were pretty good but i think i'll fix my 10bolt the other one has 509 gears in it
Offline fitz
Re: just a question
« Reply #6 on: December 13, 2009, 09:31:13 pm »
If you go with a 14 bolt get it out of a 3/4 ton. The spring perches are in a different place on the 1 ton.
Offline gotmud
    • county4x4.com
Re: just a question
« Reply #7 on: December 18, 2009, 09:18:36 pm »
havin a hard time findin a shaft i geuss there was differnet types that whent into the ten bolt mine is the small bolt pattern with the small wheel lugs every one i have found at the bone yards are big bolt patteren or the big wheel lugs with a bigger shaft im not havin fun lol
Offline gotmud
    • county4x4.com
Re: just a question
« Reply #9 on: January 10, 2010, 09:09:40 pm »
ok i got a 12 bolt givin to me in good shape so i'm gonna start putting it in tomorow now the only question i have is will the drive shaft u-joint from my ten bolt goning to fit the 12 bolt ? i heard i have to buy a special u-joint for it to work ???
Offline derrick79
Re: just a question
« Reply #10 on: January 11, 2010, 09:16:42 am »
i know it is not the same but on my 98 Z71 i swapped in a 6 lug 14 bolt after i blew up my 10 bolt. and i was told the same thing about the ujoint, however when i brought it to the driveline place they told me they don't make those ujoints anymore. so they took my old driveshaft and welded a bigger yoke on the end of it. after it was re-tubed, welded, and balanced, it ended up costing alot more than i wanted to spend. oh well it was worth it in the end.
Re: just a question
« Reply #11 on: January 11, 2010, 12:20:53 pm »
they still make those hybrid U-joints.  I think they were just after your money, how much did they hit you up for the shaft?
Offline derrick79
Re: just a question
« Reply #12 on: January 11, 2010, 08:06:35 pm »
well i went in there with all my research and showed him articles i printed online and i measured my yoke and had the part number for the ujoint i needed and he knew what i was talking about and he still said they can't get them. and i didn't feel like waiting or driving 5 hours to get another opinion. make a long story short, for my "one of a kind custom shaft" they charged me 400 bones
Offline gotmud
    • county4x4.com
Re: just a question
« Reply #13 on: January 11, 2010, 08:56:52 pm »
i was told i can order from nappa (a local parts store here) for $40 i will call tomorow and find out
Offline cdpence69
Re: just a question
« Reply #14 on: January 11, 2010, 09:06:18 pm »
get u a 14 bolt
