Author Topic: Which vacuum line do you use to suck stuff up?  (Read 13557 times)
Offline Skunksmash
« on: December 15, 2009, 08:19:54 am »
There are probly hundreds of products out there that clean the engine (or something) by being sucked up through one of the vacuum lines. You just buy the product and put it in a bottle, (if necessary) and then unhook the proper vacuum line from your truck and feed it down into the bottle with the liquid in it. Seafoam comes to mind as one of these. Anyway, which vacuum line do you use for all this stuff? Please be specific on the line's location as I am a noob. Also keep in mind I have a TBI truck so it may be different than the carb'd ones.
Re: Which vacuum line do you use to suck stuff up?
« Reply #1 on: December 15, 2009, 11:20:13 am »
Use the hose that goes to the vaccum booster.
Offline Skunksmash
« Reply #2 on: December 15, 2009, 11:25:15 am »
The vacuum booster is not that little carbon canister thing is it? Like I said I have little experience with all this vacuum stuff. Perhaps someone has a picture with the line shown in it?
Offline Layne
« Reply #3 on: December 15, 2009, 02:44:39 pm »
No picture, but that big round thing behind where you put in your brake fluid is the booster. It has a one-way check valve connected to a vac. line usually leading to the carb or intake manifold.
« Reply #4 on: December 15, 2009, 05:28:18 pm »
You need a very small vacuum line. Use one directly off the carb and sip it in
« Reply #5 on: December 15, 2009, 05:38:48 pm »
It's TBI Vile, Booster won't work as it goes into the manifold
You could pull it of EVAP or PVC on the front of the TBI.
Offline Layne
« Reply #6 on: December 15, 2009, 05:40:28 pm »
So you'd want to go through the tbi unit as well to clean that, right?
« Reply #8 on: December 15, 2009, 06:13:42 pm »
The TBI isn't as complicated as you might think.  The body where the shafts are is basically just an empty void where vacuum is drawn either manifold (under the blades) or ported (above blades)
Offline Layne
« Reply #9 on: December 15, 2009, 06:19:11 pm »
It looks like that guy used the brake booster line, then killed the motor though the tbi. I think it'd be hard to get 1/3 into everything. I suppose you wouldn't have to be exact tho.
Offline 84ramcharger
« Reply #10 on: December 15, 2009, 06:29:44 pm »
It's pretty easy to get it all in , Some guys I used to work with loved seafoaming anything they could get there hands on . I've done it a few times myself and I used the brake booster liner to pour it in then start it and quickly dump a 1/3 down the carb , let it stall then let it sit for a hr . I don't throw it in the oil though
80 GMC 2500 454/Th400
84 Ramcharger 360/727/208(?) 3.23
Offline Layne
« Reply #11 on: December 15, 2009, 06:35:19 pm »
I seafoam my citation all the time, but I just dump it down the tbi unit and the gas tank at the gas station. After I'm filled I'll crank for a minute and then drive off. I'm guessing I do it wrong ::)
« Reply #12 on: December 15, 2009, 06:41:34 pm »
I would say what your doing isn't wrong , might not be as effective as going down a vacuum line though .
« Reply #13 on: December 15, 2009, 11:28:00 pm »
I would drain the oil after I put it in there.
« Reply #14 on: December 16, 2009, 07:53:55 pm »
I used to use GM top engine cleaner all the time. Seafoam does the same but I don't think it's as strong. If you have a Carb or TBI system get the engine hot and pour it slowly into the tbi or carb at about 800RPM. Use about 1/2 the can and then pour it in quicker to stall the engine (not hydrolock it!). Let it soak for about 15 minutes. Start it up and run the rest through it. When you're done drive it til it burns off and do an oil change.
If you have a port fuel system use a small vacuum hose and let it sip it in. Vary the engine speed from about 800-1000RPM.
