Engine/Drivetrain
Howlin's drivetrain repair thread
Topic: Howlin's drivetrain repair thread (Read 7355 times)
howlinwolf
December 15, 2009, 03:54:35 pm »
exactly as it says. i need to know the size of the nut that goes on the pinion shaft. It fell off, and while there is damage, there are no broken teeth only wear. therefore i am going to replace the crush sleeve, bearing, and seal and hope for the best until i can get the beretta fixed then start on the truck. Its a 12 bolt seems like the 9and whatever ring gear.
Last Edit: December 16, 2009, 05:17:22 pm by howlinwolf
78 Chevy Custom Deluxe flatbed, PROPANE POWERED
Re: Size of the Pinion nut.
December 15, 2009, 04:48:32 pm »
Just order one by your application when you order your other parts.
⌠ŻŻŻŻŻ' [☼===☼]
howlinwolf
December 15, 2009, 05:47:44 pm »
i keep gettin told they cant get it
December 15, 2009, 05:55:14 pm »
http://www.markwilliams.com/detail.aspx?ID=839
⌠ŻŻŻŻŻ' [☼===☼]
December 15, 2009, 06:17:10 pm »
Where are you getting all your stuff from? A pinion nut should be readily available from anyone that sell those type parts.
howlinwolf
December 15, 2009, 09:56:08 pm »
a win for vile. thank you very much.
howlinwolf
December 16, 2009, 08:39:37 am »
if i have a 12 bolt rear end how many inches is it???
December 16, 2009, 03:02:17 pm »
Inches? as in what? The diameter of the ring gear?
howlinwolf
December 16, 2009, 05:16:58 pm »
no i meant the size of the rear. but its like 8.875 correct? and what years offered 3.23:1 ratio
Re: Howlin's drivetrain repair thread
December 16, 2009, 06:02:24 pm »
12 bolts are 8.875"
10 bolts are 8.5"
3.23 gears were use for the 81-87(91) trucks
howlinwolf
December 18, 2009, 03:26:40 pm »
my truck is a 78 Chevy, but the rear has been redone, but the front is all original. this truck was bought new by my grandpa. would 3.73 and 3.23 fight very much when in four wheel drive. I never noticed it, but i haven't driving it in 4 wheel much.
Engine/Drivetrain
