Author Topic: 350 BLOCK (STROKER  (Read 3560 times)
Offline 305chevy c-10
350 BLOCK (STROKER
« on: December 15, 2009, 07:11:29 pm »
WHO KNOW THE BASIC PARTS FOR A 350(383)STROKER is a 3.75 crank right and 5.7 rods
 is a 434 a 400 with a stroker kit and bored+.30over ....time for me to upgrade ........if someone can give me the details on what i need to build a 383 or 434 ......gonna try to get a pre85 350 or 400 block .....i know only one thing a stroker require a bigger crank with longer rods for a longer stroke .......im guessing.........i just want to build something with about 375-400 hp .....................thanks chevy fam
Heartbeat of America yesterday's cheverolet
18T5C10
Re: 350 BLOCK (STROKER
« Reply #1 on: December 15, 2009, 07:14:07 pm »
Kinda hard to follow you there. The crankshaft determines the stroke not the rods.
Offline eventhorizon66
« Reply #2 on: December 15, 2009, 08:19:29 pm »
You can get 375-400 hp out of a 350, no problem.  If you build a 383 (4.030" bore x 3.75" stroke) and shoot for 375-400 hp you will have the same hp but with about 30-40 ft-lb of additional torque.  IMO building a 434 (4.155" bore x 4" stroke) and only shooting for 375-400 hp would be a waste of time and money, unless you need serious low end torque.
« Last Edit: December 15, 2009, 08:24:47 pm by eventhorizon66 »
'85 C10 SWB 350 700R4 TKO600
« Reply #3 on: December 15, 2009, 10:22:21 pm »
oh i see . :o.....i thought it was both rods and crank ...........see thats y i asked u guys . ;D.......so basicaly i can change the crank in a 350 and use stock rods in the 383 ..........thanks
18T5C10
