Author Topic: power steering  (Read 11443 times)
Offline cwilson jr
power steering
« on: December 17, 2009, 02:57:12 pm »
my power steering works fine, except right after every time i start the truck, such as backing out or turning out of a parking space.  it is extremely difficult to turn with both hands.  it will then work perfectly fine.  ps resovoir is full.
Re: power steering
« Reply #1 on: December 17, 2009, 03:10:51 pm »
Hydroboost system? We usually call this morning sickness
Offline eventhorizon66
Re: power steering
« Reply #2 on: December 17, 2009, 03:45:50 pm »
The only morning sickness my hydroboost gets is an EXTREMELY touchy brake pedal until it warms up a little.  My steering is just fine.
« Last Edit: December 17, 2009, 04:10:13 pm by eventhorizon66 »
'85 C10 SWB 350 700R4 TKO600
Offline cwilson jr
Re: power steering
« Reply #3 on: December 18, 2009, 01:35:16 pm »
i believe it is hydroboost.  it's an 85.  so, this is normal for cold climates?
Offline Layne
Re: power steering
« Reply #4 on: December 18, 2009, 05:58:52 pm »
Shouldn't be. Usually morning sickness is because of worn valves allowing ps fluid to get past a little, thus making it harder to steer.  After your fluid warms up, the valves will expand a little bit to seal up.
Re: power steering
« Reply #5 on: December 19, 2009, 05:12:25 am »
In cold weather, power steering fluid thickens in the same manner as any other petroleum-based oil or fluid. Upon cold starting, the fluid resists movement through the system and the driver senses reduced power assist (sometimes referred to as "stiff steer"). As the vehicle operates and fluid circulates through the power steering system, the fluid warms and thins to its normal operating viscosity.
CORRECTION:
Saginaw Division has developed a new Low Temperature Climate Service Fluid for use in cold climates. Compared with conventional power steering fluid, this new fluid flows better at low temperatures and resists the thickening which contributes to reduced power assist upon start up.
Low Temperature Climate Service Fluid is available from GMSPO. Order as:
Parts are currently available from GMSPO.
SERVICE PROCEDURE:
The power steering fluid replacement procedure is a two-stage process: first, flushing the old fluid from the system with new fluid; and second, bleeding the system to remove any trapped air. The two sequences outline the steps in each procedure.
FLUSHING THE POWER STEERING SYSTEM1. Raise the front end of the vehicle off the ground until the wheels are free to turn.
2. Remove the fluid return line at the pump reservoir inlet connector.
3. Plug the inlet connector port on the pump reservoir.
4. Position the fluid return line toward a large container in order to catch the draining fluid.
5. While a second person fills the reservoir with new Low Temperature Climate Service Fluid, start and run the engine at idle.
6. Turn the steering wheel from stop to stop.
 NOTICE :Do not hold the wheel against stops while flushing the system, Holding steering wheel against wheel stops will cause high system pressure, overheating, and damage to the pump and/or gear.
7. Continue draining until all of the old fluid is cleared from the power steering system. Addition of approximately 1 quart of new fluid will be required to flush system.
8. Unplug pump reservoir inlet and reconnect return line.
9. Turn engine off, and fill reservoir to the "Full Cold" mark.
10. Continue with following procedure "Bleeding the Power Steering System".
BLEEDING THE POWER STEERING SYSTEM
After replacing the fluid or servicing the power steering hydraulic system, you must bleed air from the system. Air in the system prevents an accurate fluid level reading, causes pump cavitation noise and over time could damage the pump. To bleed the power steering system proceed as follows:
1. Begin with the engine off, front wheels off the ground, and wheels turned all the way to the left.
2. Add Low Temperature Climate Service Fluid to the "FULL COLD" mark on the fluid level indicator.
3. Bleed the system by turning the wheels from side to side without hitting stops.
 Important :This may require turning the wheels from side to side twenty times. On systems with long return lines or fluid coolers, turning steering wheel lock-to-lock forty times may be required. Keep the fluid level at the "FULL COLD" mark. Fluid with air In it has a light tan appearance. This air must be eliminated from the fluid before normal steering action can be obtained.
4. Start the engine. With the engine idling, recheck the fluid level. If necessary, add fluid to bring the level to the "FULL COLD" mark.
5. Return the wheels to the center position. Lower front wheels to the ground. Continue running the engine for two or three minutes.
6. Test the vehicle to be sure the steering functions normally and is free from noise.
 Important :Inspect for fluid leakage at connection points along the power steering system.
7. Recheck the fluid level as described in Steps 3 and 4 except that the fluid level should now be up to the "FULL HOT" mark after the system has stabilized at its normal operating temperature.
