Manual Steering Conversion
Topic: Manual Steering Conversion (Read 16289 times)
327power
December 19, 2009, 06:09:28 pm »
What do I need to do to convert my truck to manual steering besides get the box? Can I just bolt on the manual box and connect the pitman arm and go? I like Manual steering because it simple and clean.
LIVE FREE OR DIE
Re: Manual Steering Conversion
December 19, 2009, 06:23:17 pm »
Yeah but have you ever driven one of these trucks with manual steering? I would advise against this down grade.
CoggedBelt75
December 19, 2009, 08:37:48 pm »
x2 on that!! When I put the blower on, I also thought I would "clean things up" by going to manual. Went to the salvage yard and found a box, arm, and rag joint and swapped everything out. Big mistake!!! Even tho it did look cleaner, no pump and pulley, no belt, no hoses, but it sure was a royal pain in the butt to drive. Didn't take long to swap back either. I highly advise not to go this route.
Joe
1975 C10 blown 383
Layne
December 19, 2009, 10:47:42 pm »
when I got my truck all rigged up with a new motor and trans, I was as, or more excited for my new power steering!
327power
December 19, 2009, 11:48:51 pm »
lol...It's ok. I've had a bunch of manual steering trucks. No problem. I don't mind. I just never converted one, which is why I inquired. Thanks.
LIVE FREE OR DIE
CoggedBelt75
December 20, 2009, 09:59:27 am »
In that case, if you're pulling a used box, be sure to get the arm and rag joint that is on it. They have an entirely different shaft and spline than the power one. If new, just get the matching ones. Other than that, pretty straight forward swap. Wasn't trying to rain on your parade, just offering up my experience on the matter
. But to each his own, that is what keeps everything different. Once you make the swap, come back and give your thoughts on it.
Joe
1975 C10 blown 383
327power
December 20, 2009, 04:17:30 pm »
Thanks, CoggedBelt75. I know a lot of guys love their power steering. I don't mind it either, but manual steering has been preferred to me for its simplicity. Like I said, I never had any problem with a little more resistance in the steering wheel.
So the box, rag joint and pitman arm and I'm ready to go? Thanks!
LIVE FREE OR DIE
CoggedBelt75
December 20, 2009, 06:06:01 pm »
Yeah, other than a good pair of arms
,that's all you will need. I had plenty to choose from since there are plenty of old farm trucks in our area yards. If going used, look for one that is nice and tight and doesn't have any binding or sloppiness when rotating the pitman arm. Maybe the only other thing you will need is the rubber on the rag joint, which I did replace, since most are weather rotted pretty bad. But O'reilly auto parts carrys that item in their help section.
Joe
1975 C10 blown 383
December 20, 2009, 06:22:06 pm »
May want to hold on to your Power stuff also. If you haven't driven one of these 73-87's with manual in a while, you will be changing it back. On top of the fact that the power steering box has a faster ratio.
