Author Topic: No Front parking lights  (Read 15633 times)
Offline BigBlue
« on: December 20, 2009, 09:59:57 pm »
Hi, I have done numerous searches and can't locate a solution to my issue so here goes: I'm working on a friend's 1980 k10. It came to me with no engine and now that I'm getting ready to give it back to him I noticed it does not have any front parking lights when the headlight switch is on. Both blinker lights in the dash come on with the headlight switch (indicating a bulb isn't working somewhere I believe). The rear taillights work fine. All blinkers, headlights, hazards and brake lights work fine. The bulbs in the front parking lights are good. All grounds check out good. I removed the firewall to fuse block connector on the firewall side. Everything looked good. I know the grounds are good for the parking lights since the blinkers in the front work fine but I cleaned them all anyway.
Does anyone have any suggestions where to go from here?  Thanks.
Re: No Front parking lights
« Reply #1 on: December 21, 2009, 12:56:18 am »
do the turn signals work with the headlight being on or off? i would also check the bulb to make sure its the right bulb it should have two contacts on it.
Offline BigBlue
« Reply #2 on: December 21, 2009, 06:31:05 am »
Yes, the turn signals work fine with the headlights ON and OFF.
Both bulbs are amber colored 1157 bulbs. I've used my dvom and check for continuity on each contact of the bulbs with the bulbs removed. I do not think I'm getting +12v to the parking light wire from the firewall connector.
Not sure what to look at next or where the parking light wire from the headlight switch connector splices into two wires, one for the rear taillights and one for the front parking lights.
I'm thinking I may have to pull the fuse block from under the dash but wanted to get some insight from anyone here before I did so.  Thanks!!
« Reply #3 on: December 21, 2009, 10:30:31 am »
Are any of your marker lights blown?
Offline BigBlue
« Reply #4 on: December 21, 2009, 11:02:23 am »
The side marker lights on the fenders both work when the left and right turn signals are on. I believe these are single element bulbs right?
Offline BigBlue
« Reply #5 on: January 29, 2010, 12:55:47 pm »
Jus checking to see if anyone has any advice.  Thanks!
« Reply #6 on: January 29, 2010, 03:29:35 pm »
so you have turn sigs but no parking lights? and yes the side markers are single
Offline BigBlue
« Reply #7 on: January 29, 2010, 06:38:11 pm »
I have turn signals (side marker lights work as turn signals) with headlights ON and off.
With parking lights on, I only have rear parking lights and no front parking lights or side marker lights.
With headlights on, I only have rear parking lights and headlights but no front parking lights or side marker lights.
« Reply #8 on: January 30, 2010, 01:52:43 am »
Trace the wires to the junction box on the fire wall, for power to the front running lights and check for power. I know you said you looked at it but just check it with a tester and see what you come up with. Then if that checks out test the a running light up front and see what it shows
« Reply #9 on: January 30, 2010, 07:09:33 am »
Double check the ground connections on the front harness. Use a test light to verify b+ at each socket.
Offline DnStClr
« Reply #10 on: January 30, 2010, 06:51:59 pm »
Yes. check those grounds again Big Blue. Take them apart and clean. Also, from a wiring schematic it looks like the b+ should be found at the blue wire and brown wire on the right hand parking light and also at the lt. blue and brown wires on the left hand parking light.  The brown wire runs between the two lights to tie them together.
It looks like the b+ voltage originates at the instrument cluster circuit board.
Don
87 Chevy Silverado
Offline BigBlue
« Reply #11 on: January 31, 2010, 04:48:43 pm »
Okay, thanks for everyone's help. I think I may have made some progress today but still need some advice.
If i pull the both front 1157 bulbs, both fender marker lights come on with the parking lights engaged. I have triple checked all grounds, both blinkers work fine. I have checked and have +12v inside each 1157 connector on the parking light terminal (when using the battery as my ground on my dvom). HOwever, if I check for ground through the ground terminal in the 1157 connector I can not get one.
Is it possible both 1157 connectors are bad?
« Reply #12 on: February 01, 2010, 03:42:52 am »
check the ohms between the socket and b- see what you get. is each socket grounded independently
Offline BigBlue
« Reply #13 on: February 01, 2010, 05:24:26 am »
Did that yesterday. First off, each socket is grounded together with all the other bulbs through a splice.
Using b-, I get 0.1 ohms when probing the socket ground wire just before the wire goes into the connector. Then if I check the actual metal terminal ground strip in the connector I get OL on both connectors. This leads me to believe both connectors have a bad ground connection internally.
It's not my truck and I don't know if these lights ever worked right. I'm repairing the truck for a friend and it had sat for a couple years. Thanks for all your help.
« Reply #14 on: February 01, 2010, 08:29:48 am »
think ur right sounds like the ground is the problem in the socket. it is weird how both are bad
