General Discussion
Who has a 4L80E 4WD in their truck?
Topic: Who has a 4L80E 4WD in their truck? (Read 13128 times)
December 21, 2009, 07:54:59 am »
I need a few pix and measurements if anyone can help me out. Again 4x4 4L80E application. I need to know the length of the extension housing and whether or not it's aluminum or iron. Some pix would be cool too. I'm trying to come up with a conversion. Thanks!
1HI4x4
V30 Crew now a shortbed.....
Re: Who has a 4L80E 4WD in their truck?
December 21, 2009, 08:02:48 am »
I have one what exactly are you looking for, I'll go get it for you?
1988 V30 Crew Cab, Cummins power, 47RH-NP205, 8" lift, 13.50x35x20 Fuel Mudders on 20x14 XD Diesels -76 offset. Soon to be repainted, seats from a 2010 Lariat to be installed.
1HI4x4
December 21, 2009, 08:33:09 am »
It is 4.5" from the rear of Trans to the face of NP205. Here is a picture but it's not much to go by.
1HI4x4
December 21, 2009, 08:35:42 am »
It's iron also.
Lt.Del
Andy aka:SgtDel
DelbridgePhotography.com
December 21, 2009, 09:21:40 am »
i have one in my 91 V2500 sub. I should have some pics on my hard drive at home. I don't think I'll be getting under it within the next few days with all the snow and slush. As much as you have helped us out, I'd more than welcome the opportunity to help you out anyway i can.
http://forum.73-87chevytrucks.com/smforum/index.php?topic=12080.0
Last Edit: December 21, 2009, 09:23:51 am by SgtDel
www.DelbridgePhotography.com
www.HikerMania.com
www.delbridge.net/suburban
December 21, 2009, 03:21:03 pm »
Thanks guys, the more pix the better. I have a 2wd 4L80E that I am converting to 4x4. I located an output shaft and 4x extension housing. Now I haven't decided what I'm gunna run for the Tcase yet. This is for my 75 Blazer -462BB EFI, 4L80E, Transfercase options I have; 203 converted, 208 or a 241. I have to check on the spline count on the 203 still so that may not even be a worthwhile option...
Anyway thanks and a few more pix would be great whenever you guys get a chance. Thanks!
fitz
December 21, 2009, 04:24:29 pm »
I have one in my 2000 crew cab. I can put it on the lift and get pics if you want.
If you run the 241 t-case keep in mind the 89-90 run the mechanical speedo and the 91 runs the electric one.
December 21, 2009, 04:33:34 pm »
Yeah the speedo won't be an issue either way as I have multiple gauge options I'm playing with still so whatever combo I go with I will factor that in as I go.
Lt.Del
Andy aka:SgtDel
December 21, 2009, 06:41:00 pm »
some pics i had on my computer...i can take more after a foot of snow melts...
Last Edit: December 21, 2009, 06:43:28 pm by SgtDel
www.HikerMania.com
Chevalade
December 21, 2009, 07:30:43 pm »
Go with a doubler....203/205. Would be great with a 4l80.
December 21, 2009, 09:16:07 pm »
ehhh.... not really practical for any usage this toy will see. Thanks sgtdel but what I need to see is the extension housing set ups since there were several variations of the 4x4.
Lt.Del
Andy aka:SgtDel
December 21, 2009, 09:31:01 pm »
i'll see what i can do, and try to get some measurements.
www.HikerMania.com
December 22, 2009, 06:29:30 pm »
Thank you!
Lt.Del
Andy aka:SgtDel
December 26, 2009, 08:30:15 pm »
Viles, I'll try to snap some pics tomorrow (Sunday). I've had a bit of a cold bug for three days. Better now, and I can crawl under the sub and snap a few shots.
www.HikerMania.com
Lt.Del
Andy aka:SgtDel
December 27, 2009, 01:13:18 pm »
extension housing......i hope this helps....
If you need any other shots, just say...
www.HikerMania.com
General Discussion
